XJ11 Spark plug thread repair
  • kristo.thaler@gmail.com
    • Feb 2016
    • 19
    • Milwaukee, WI.
    Hey everyone,
    I got my bike last october and she died on me at work in early november. I replaced the spark plugs one night in an attempt to get her to start. Anyways, it was cold and dark and I crossed 2 of the threads. Didnt look too bad, vacuumed out the shavings and put them back in, but when I finally got her started again (wasn't the spark plugs) they werent holding pressure. It definitely showed in her performance as well.
    The question is: What are my options?
    82 XJ11
    You should be able to use a 14MM spark plug Helicoil, available at auto parts stores.
      • 4015
      +1 But, are you sure the spark plugs were threaded properly? This very thing happened to me. I heavily greased the threads, and used a chaser.
        • Feb 2016
        • 19
        • Milwaukee, WI.
        Yes, I believe they were threaded properly. I also greased them and it still didn't hold pressure. If I am to use a Helicoil, which 14mm should I use? There seem to be several different types.
        Last edited by kristo.thaler@gmail.com; 03-01-2016, 08:15 AM. Reason: Added Helicoil question
        82 XJ11
          The HeliCoil kit that will work on our bikes is part # 5334-14.
            Here is an alternative repair.
            threaded inserts threaded, stripped threads, threaded inserts, blown out sparkplugs, stripped threads, stripped out theads, inserts threaded inserts, ford sparkplug repair, threaded insert thread repair spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threaded inserts for stripped threads, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts, striped out threads, threaded inserts, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
            • TomB
              • 967
              • Cumbria, UK
              I've used both Helicoil and Timesert, both good kits, but the Timesert is much better as there is no risk of the insert screwing its way into the cylinder when screwing in a spark plug.
              Tom
                • Feb 2016
                • 19
                • Milwaukee, WI.
                Thanks for the help guys! Bought Helicoils and thread lock to keep them from losing their place.
                82 XJ11
