Front Tire on Rear?
    Front Tire on Rear?
    My Bagger project has a Dunlop D404F tire on the rear. The tire clearly says on the sidewall that it is for front use only.
    Is this unusual? Unacceptable? What makes a front tire different than the rear?
    Another problem....I can't understand the DOT date code. It is 5644? The 56th week of 1944? I can't find any other numbers that would be the right date code.
    Mike That tire will not last very long on the rear. Keep looking for the manufacture date.
      Take a closer look at the DOT number. I got a bike a while back with a brand new 130/90/16 front tire on the rear. Put it on ebay for $50 and some Harley rider snapped it up. That's what it fits on.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        ... I can't understand the DOT date code. It is 5644? The 56th week of 1944? I can't find any other numbers that would be the right date code.
        Mike,
        You're looking at the wrong code on the tire.
        On your Dunlop, first look for the DOT raised stamp.
        To its right, there will probably be a 4-digit alphanumeric code, followed again by another 8-digit alphanumeric code placed inside a long oval shape.
        This 8-digit code is the one you want, and its last four digits will tell you the manufacture date of the tire.
        The entire sequence will look something like this:
        DOT EUM5 (+NA7M2705+)
        In this example, the tire was manufactured in the 27th week of 2005.
        Of course, this info assumes the tire was manufactured in the year 2000 or later. If before the year 2000, the code gets a little funky.
        But then ... you'd be replacing it anyway ...
        Hope that helps!
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
          I accidentally ended up with a front tire on the back of my XS11. It was completely worn out in 1500 miles. It's just not going to work.
            • 4015
            Marty had the wrong tire put on his bike. It happens. Replace it.
              Ahhhhh... I see
              Thanks, guys for being so helpful.
              Marco: Once you described what I was looking for, it was easy to find/understand the DOT date code. I found NA7M1806 -> 18th week of 2006. Not as new as the PO had stated (~4years). I was interested in the age to determine if it had an resale value.
              Greg: Yup- exact same tire 130/90/16 Helpful to know it's marketable as an old Harley tire with almost no miles.
              Overall, sounds like the consensus of what is different for a front tire is longevity. So I compared the tread with my Spitfire rear tire and noted the surface area ratio of rubber to grooves is much lower on the front tire than the rear tire- makes sense- more rubber wears longer, less critical for water in the rear.
                Wow.. A tire thread about incorrect placement of a tire and people haven't come out of the woodwork telling them they were going to "crash and DIE!!"
                Good job people. I'm proud of you.
                But just remember, if you do run that front tire on the back and put 40 psi in it, you'll CRASH AND DIE, DIE, DIE!!!
                Instigator out.
                  Well, it's usually a case of several things, but generally, the front tire has a much lighter load rating than the rear tires do, as well as different compounds. A tire working past it's load rating is going to wear a lot faster than , well.. the right tire for the job. That being said, I've never seen much more wear out of a D404 than 1500 miles anyway on the rear.
                  • Eastcoaster
                    • Jan 2012
                    • 513
                    • oceancity NJ
                    me 2
                    Strange I am in the same situation I just found a front Dunlop 491 on the rear of the 79 I just picked up. Ordered new tires I was not sure if this was OK to do now I know
                    82 XJ1100J
                    81 Venturer
