Hi all, here is my dilemma.
I wanted to go for a ride yesterday morning since we are having some really nice weather here in south Louisiana but for the first time in nearly 35 years I have owned my machine I am having starting/running problems. Saturday afternoon it started and ran very nicely but Sunday was another story. I admit electrics are not my forte and I know the problem is electrical.
Here are the symptoms and conditions. Started up and ran fine Sunday morning for about 15 seconds then killed dead. No starter when I tried to re-start. All accessories like headlight, turn signals, horn, etc work fine. Battery is in full charge. I took the side cover off and fuses are all good. Tried it again, the starter functioned and it started and ran for about 10 seconds and killed dead again. I checked the emergency stop switch and it looks good (the handlebar controls are only about 3 years old) but I did not test anything. Throughout the course of the afternoon I tried it off and on but no starter.
Would the solenoid under the right side cover cause the motor to kill and then no starter function when you try to start again? If so, how do you test it? I'm at a loss for ideas!
Does anyone have suggestions of what I might be looking for?
Thanks in advance for your help.
). I thought it was the crimps but found that the slot that one of the fuses was in had crack in one side. I moved the wires and fuse to the next empty slot and the problem went away. (the fuse box had 6 slots and was only using 4)
