I have a 78 Standard frame, carb set, good wiring harness, TIC module, etc. but the motor has a hole in the crank. I have an 82 Maxim motor that on has 17 k miles.
I want to drop the 82 motor in but am wondering about the ignition system. I do not have the TIC for the Maxim. Can I use the 78 TIC or will I need to swap out and put in old pickups and vac advance from the blown motor?
I have started stripping everything down and should have the motor out of the frame tomorrow.
I will need to stop and buy / make a good buffing wheel before I get to much further along.
