Steering head bearings numbers
  • Roncoach70
    • Aug 2015
    • 84
    • Myrtle Beach, SC
    Does anyone have the numbers for the upper and lower steering head bearings for a xs1100SF or a source.
    Thanks
    79 XS1100SF
    79 XS1100SF parts
    79 RD400F Daytona Special
    • 9981
    http://www.ebay.com/sch/i.html?_odkw...rings&_sacat=0
    Ebay is your friend.......
    • Roncoach70
      • Aug 2015
      • 84
      • Myrtle Beach, SC
      Thanks Greg...again.
      Ron
      79 XS1100SF
      79 XS1100SF parts
        Originally posted by BA80
        Ron Note most of those listed are UK /England which will have high shipping costs.
          • 9981
          A good many of them are within the US and offer free shipping too.
            ..........a local bearing house supplier should be able to reference the mumbers, or cross-reference numbers. IIRC, yamaha's patent ran out so other supplyers are stocking them now{that size is used in other applications}. May be worth checking out.
              • 9981
              Yes but first you need to remove the races INTACT to get the numbers off them and these kits are the only place to get new seals I know of.
              • Roncoach70
                • Aug 2015
                • 84
                • Myrtle Beach, SC
                Thanks everyone, Do I need a bearing press or can I tap the new races in with a punch and hammer. Any thoughts?
                Thanks
                Ron
                79 XS1100SF
                79 XS1100SF parts
                  • 7830
                  You can use a hammer to get them in and out. The bottom one you have two SMALL notches to push the bearing out with. It's sometimes VERY HARD to see them unless you really clean out the inside of the neck. I use the old race, grind the edge a little so it slips in and out, to press the new bearing in place.
                    • 9981
                    The top one is pretty easy to get out, the bottom one is a bitch.
                    The easiest way I've found to get that lower race out is cut it with a dremmel cutting wheel as far through as you can. It will most likely crack along the cut and then it'll almost fall out. It's really hard to get a good bite with a punch to knock it out otherwise.
