That's a good thought Bonz, However I did adjust the cam chain tensioner, Thanks
knocking noise at RPM above 3000.
IF it's the factory unit, I would NOT trust it! Go with the ACCT upgrade! I have had the factory one "back off" when running hard, so I no longer trust them. Just my $0.02, but there are a LOT of the bikes now running with the Venturer adjusters here.Ray Matteis
XS1100 SF Bob Jones worked on it! -
Ranger, I was addressing the OP with that question... but it does apply to you as well. Glad you are still interested in the thread which he seems to have lost interest!
In any case, what DiverRay said is where I was going with the question. The ACCT mod is a great way to ensure it isn't the cam chain because of a known ineffective stock tensioner.
I did it on my 80SG and 80G, easy peasey and should be a must-do mod.Last edited by Bonz; 12-26-2015, 10:50 PM.Howard
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550Comment
Knock
Back on the "knock" thing. I have found three things in the OEM design to be wrong. I know, with OEM 4 ME call sign, WTF.
First, the fuse box, everyone knows it is junk and should be replaced before trying to figure out why your bike runs poorly, start there, its cheap, easy and will fix a lot of crap.
Next the electronic ignition and octy. Both great ideas ahead of there time. Here is the problem, the vacuum hookup. You need to balance all the cylinders vacuum into one constant flow and then reduce that flow the same way you do on your carb vacuum gauge's so the octy and ignition advance don't jump around like crazy and ware out the octy diaphragm and the advance wire leads.
All an easy fix. But the 3000rpm "knock" noise is most likely the advance jumping around and causing that rattle and jumping in the motor sound / pull. If it smooth's out when you increase the throttle and decrease the vacuum, well the explains it. Yamaha did a tech. paper back in the day.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
