Hi all.
My 81 Special has had a fairly loud knocking noise above 3K RPM for some time. It also seems to be affected by engine load. If I'm cruising at say 60 mph in 4th it is loudest but if I accelerate or climb a hill it seems to go away. If I actually knew anything about this engine, I would say it sounded like either a connecting rod big or small end or maybe a crank bearing. the nature of the noise doesn't really sound like the cams or rockers but I suppose that could be it. I did have one mechanic say he thought it was the vacuum advance mechanism. The thing runs great and has no unusual vibration or oil usage or leaks. Any suggestions are welcomed.
Thanks.
Thanks.
