Volt meter for a Vetter fairing
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    [IMG][/IMG]
    I have wanted to install a volt meter in my Vetter fairing. There is not too much room. I found just enough on the side opposite the antenna location. this one worked perfect.
    http://www.amazon.com/gp/product/B01...ilpage_o01_s00
    650SF
    XS1100SG Project bike
    Originally posted by Rickrod3
    [IMG][/IMG]
    Ya...........but your voltage is bout 3+ volts to low. Hpe you know how to souce out the issue such as plug-ins, ignition switch, kill switch, the three grounds under rear hold-down bolt of votage regulator, etc.. Had to relook at that pic............88.8v..........workin' perfect........give me a break!.......how bout a pic of voltage reading with bike runnin' and at an idle?
    • mikubuilder
      • Jul 2011
      • 548
      • Westland, Mich.
      I put exactly same one on the other side, where a cig lighter hole was...yeah the display is only good in dim light, during the day you cannot read it
      Mine is pretty accurate, about 14 VDC when riding, drops to about 11.2 VDC when idle
      Nick
      1982 Virago 750 (it's alive!)
      • Rickrod3
        • Jun 2009
        • 721
        Coming soon @ 3000 RPM I'm getting 13.7 volts I recently cleaned my ignition switch and my turn signals now blink when idling.
        650SF
        • Rickrod3
          • Jun 2009
          • 721
          I though about the cig lighter but thought it may come in handy for something else later. (even though I have never used it) the spot I put it in works well. Maybe since its slightly recessed.
          650SF
            Remove the kill switch and dis-assemble and clean. Careful that the teeny spring when disassembling doesn't boing out and hide in the man-cave somewhere unknown. Doing that may give you the 14.2v at approx. 3K rpms.
            • Rickrod3
              • Jun 2009
              • 721
              Where is your volt meter taped in?
              650SF
              • Rickrod3
                • Jun 2009
                • 721
                I have my meter taped into the blue wire Running light.
                Red wire feeds the ignition switch when the ignition switch is closed power goes to blue which is the running lights and brown which I believe goes back to feed a few circuits in the fuse box. I don't believe the kill switch is in that circuit. I did address it a few years ago though.
                I'm thinking the load of the lights may be dropping the voltage. Hmm I'll try pulling the running light bulb and see what voltages I get.
                650SF
                • Rickrod3
                  • Jun 2009
                  • 721
                  here is the bike idling with the choke on
                  650SF
                    Hi Rick,
                    13.9 or 888 depending on the angle of my screen
                    Is it easier in "real life" or is the angle critical?
                    • Rickrod3
                      • Jun 2009
                      • 721
                      Hi Rick,
                      Hey Phil
                      When the sun hits the volt meter it is difficult to read. The first day I used the volt meter, the day was overcast so I had not noticed that. For the most part it is pretty readable. I added it so I could run heated gear, and a GPS while monitoring charging system.
                      BTW its 13.4
                      650SF
                        Hey Phil
                        BTW its 13.4
                        Hi Rick,
                        It is a nice compact size which makes it easier o mount in a fairing. So like many things it has some pros and some cons. I mounted an analog volt meter when I added driving lights and am very glad I did. Would have been stuck at the side of the road at least twice with out knowing I had run my battery down due to overloading the system. The compact size and low $ is very tempting.
                        • Rickrod3
                          • Jun 2009
                          • 721
                          Hi Rick,
                          Yes compact size and ease of installation. If you have a Vetter or the Venturer with the Vetter style fairing like we do this $9.00 Mod is a no brainer.
                          650SF
