I have a 1982 XJ 100 Maxim that I bought two years ago and has been a great, reliable runner that I use use on a nearly daily basis and has run nearly flawless on two 800 mile round trips this summer to both San Diego and Los Angeles. (I live in Las Vegas)
My question is, two days ago, the ignition cutout and stopped the engine.
It happened once in Long Beach, and again a few months' ago, both for just a second and went away.
Then while on a ride around town, I stopped at a red light and while waiting, it did it again. The last time it happened, I thought the kill switch was slightly "OFF" and so I checked it first. All normal key ON lights were lit, but the starter would not work. after a few tries, everything was fine and I had it running before the light turned green.
Down the road, after a stop for an errand, it started up, ran for four seconds and cut off again. Repeated switching of the kill switch and key on and off did nothing. I started to check fuses and wiring under the seat and after wiggling here and there tried the starter and it fired up.
I made it another 2 miles down the road and it all started over again.
I don't think I actually 'fixed' anything, but I naturally want to know what could cause the dash lights to be ON, ready to start, but no response from the starter button, the, as if its like a circuit breaker 'resets' itself and everything is good.
I checked the main fuse, and tried the key with it both in and out, and or course with it out I had NO lights/power at all.
The fuses were all OK and the only other things I saw were the two flasher units for the signals and hazard lights.
Does the main ignition module have an electronic circuit breaker? For how intermittent it is, I don't think the problem is the wiring/ignition unit on the left side of the engine case.
There is no warning before it occurs, or ill effects after it ends, and has done it both stopped in traffic, and smooth cruising without hitting any bumps or jarring of any kind.
Sorry if this got longer than I meant- Anyone else have this happen or know what could cause it? Many thanks for info-
Brian in Las Vegas
Brian in Las Vegas
. Remove it and take it apart, taking care not to have the tiny internal spring boing out somewhere in the man-cave. Take the switch itself and all internal pieces and soak them overnite in a shot-glass full of Evapor-Rust. rinse clean and blow dry every part, including switch itself. Re-assemble using a tad of dielectic grease and remount on handle bars. Also, the plug-in at top of frame under tank on right side is its connector. Unplug it and throughly clean those contacts and re-assemble. That is the easiest starting point. NOW check that voltage at that plug-in is same as batt. voltage, key on, batt. voltage needs to be the same at plug-in. If it is lower, your gonna have to check and clean ALL grounding locations. That'll be a good start and report back here to your findings........we can then steer you in correct direction for more checking
. BTW, the kill switch completes the running circuit, as I'm sure you knew.
