Hi all.
I am having difficulty with my 78XS1100E that I bought some 3 mth. ago. The problem is carb. continues to overflow into air
intake even after all the following work has been done:
. carb. completely disassembled and thoroughly cleaned
. floats checked for bouyancy and all floats (with hinges) 80% submerged.
. float height set to 26mm with gauge
. float valve needle and seat polished...still overflows
. new needles and seats installed
. gas level checked using Ken Talbot's method. Level in #1,2,3 the same, level in #4 1 mm lower, i.e. within tolerance. Float valves worked as required. Gas level approx. 10 mm below underside of carb. throat.
. Carb. reinstalled and prime switched on. No leakage.
. Engine started after several cranks. Running rough and LEAKING AGAIN through air intake drain.
Any and all suggestions will be greatly appreciated.
Roald, Madoc, Ontario
