Oil drain plug
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Oil drain plug
    Question for all the experts out there which I am not. Just got bike this year, only 430 miles since i am new to riding and my first bike which i picked up for $400 thanks to my lovely wife who saw on Facebook garage sale. I see where the oil filter case is up front of bike but how about drain plug. Do i need to take case of to see it and drain it? Any pics possibly to show me? Thanks.
    79 xs1100 special
    79 XS11SF
  • mack
    • 2411
    • Ontario, Canada
    Right behind the
    oil filter housing is a ribbed pan. At the back of the pan is a 19 mm hex head bolt. That is the drain plug for the motor.
    The middle drive also has a drain plug. It is located at back of the motor, in the center practically in line with the rear motor mount/forward foot peg bolts.
    The last drain plug is located under the final drive. Also a 19mm hex head bolt.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      To drain the oil you need to remove the bowl that holds the oil filter and also remove the drain plug that is to the right of the filter bowl when looking back at the engine from the front side of the bike. The drain plug faces forward and you gotta get pretty low to the ground to be able to see it.
        Hi DBMB,
        Behind and towards the (rider)left side is the drain plug for the Engine Oil. Faces forward in a recess. Be careful not to over tighten when putting it back in and always use a new (or annealed) washer. Plenty of oil threads to guide you in what to put in
        Also remember middle drive and rear drive are separate and need checking and changing too.
        You need our good friend CatatonicBug..... http://www.ringler.us/family/mybike.html
        while the whole page is worth a read look for the Shop Manual
        And Welcome to the madness
          This is with the filter cup off (And an oil cooler adapter on) but red arrow is drain plug. Be very careful on re-tightening. These strip easily.
          • dbmb0416
            • Jun 2015
            • 128
            • Westdale Ny
            Thanks everyone.
            79 XS11SF
            • LabidySabidy
              • 25
              • Dallas, TX.
              Welcome
              Here's a link to the full service manual if you haven't come across it yet. Bare in mind its a large file and will take some time to load, but I use this as well as this website as my go-to for any maintenance. Best of luck!
              Kasim
              1980 XS1100 Midnight Special "Delilah" (First Motorcycle)
              "The depth of my struggle shall determine the height of my success."
                And Tod comes through with the pic!
                • dbmb0416
                  • Jun 2015
                  • 128
                  • Westdale Ny
                  I have a full Manuel printed out. I quickly looked the other day without it on center stand. So I'm assuming you have to take off oil filter and once you do it's easier to see? Previous owner changed filter and oil before selling it to me so I really just wanted to change oil only before winter so I could just put tank and fenders on which are getting painted over winter. Thanks again everyone. Great forum.
                  79 XS11SF
                  • LabidySabidy
                    • 25
                    • Dallas, TX.
                    If looking at the belly of the bike from the front it should be to the right side of the filter cover. Removing it may make it easier to see but will make the oil change job a whole lot messier. Study the picture posted by trbig and understand that the circular part or where the oil filter cover bolts on to. On my bike at least I was able to identify and remove the oil drain bolt without removal of the oil filter cover.
                    Kasim
                    • tomcos67
                      • Apr 2015
                      • 311
                      • Amsterdam, N.Y.
                      If you going to change oil u should change filter.Two things to be careful of one when changing filter,,,, don't throw away spring and washer that are underneath oil filter.In the housing itself. .And if not there get one.When I bought my bike it wasn't there someone never put back or didn't know any better And I didn't know about it,,, so I put filter back on without it.??Then I got manual.!!.And as previously mentioned don't over tighten that drain plug.!!!!They strip so easy.!!!!Otherwise you will be looking for oil pan as I did ...
                      1980xs1100.sg Pacifica Fairing ..stock.
                      2006 Honda Shadow Spirit 1100.! ⛺
                        Hi Kasim,
                        If you are sure the oil and filter were recently changed I would leave it until spring. When you do drain it remember the flow is coming out at 90 degrees to the floor and gravity wins in the end. Usually this results in the dirty oil missing the catch basin Makes a nasty mess
                          Use a six-point socket or open-end wrench to turn the filter bolt to prevent rounding the head.
                            An open end wrench? Why not just a set of channel lock pliers or vice grips?
                              .......+1!.........bout as thoughtful as tryin' to use a pair of plyiers. No offense, but bout as worst advice I've seen.........hope that was intended as a joke!
