I really need help!
    Originally posted by mrtkayak
    Well I need to check this too. By the way where and what is a vacuum plugs he he he.I need to get a manual for this bike.Thanks bro!!!
    He is talking about the little rubber caps that go on the brass nipples on the carb intake boots. Also make sure the vacuum advance hose in plugged into the brass nipple on the #2 carb body and not the intake boot nipple.
    Along the lines of vacuum leaks, make sure that the vacuum line going to the fuel distribution block, (known as the octy) if you still have it on there, are not leaking either. This line should go to one of the brass nipple on the intake boots.
      • 2139
      Things that have happened to me before:
      (1) Vacuum leaks (mine was butterfly shaft seals)- After the bike was warmed up and I came to a stop, the idle would gradually drift up to 2-2.5k.
      (2) Rich pilot jets (K&N instead of Mikuni)- Idle was always fast and erratic. I'd get it settled down, then when I blipped the throttle, it would go up and not come back down- I could see and smell it was way too rich.
      Good Luck.
        Originally posted by BA80
        Wrong jets Brant.......pilots should all be the same. Mains are richer on 2 and 3 on a few years.
        Thanks for the correction Greg.............just dealing with my 81Venturer bit me......again.
          Hey there MrT,
          I sent you the link to the ONILNE manual(s) from Catatonic Bug's site in your registration confirmation email!
          • MPittma100
            • Aug 2011
            • 2359
            Diaphragms
            VERIFY that the diaphragms are tight on the slides. Should not be able to turn the slide within the diaphragm. If any are loose, a correction is required.
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              I'm glad you said something about that Mike, it reminded me of a question I've been meaning to ask here.
              I have a set of slides that have perfect diaphragms on them but they all spin on the slides. The rubber is tight in the rings but the rings are loose on the slides so they won't stay properly oriented.
              Trying to figure out how to fix them.
                Hey Greg,
                How about just applying some superblack Oil/fuel resistant RTV to the TOP side of the slide/diaphragms where it won't be exposed to the fuel fumes. And since it's just next to the slide/thick portion of the diaphragm it shouldn't interefere with the flexibility or action!? JAT?
                  The plastic rings are loose on the slides. Thought about maybe some epoxy but I don't really like the idea.
                  • rdmcguy
                    • Jul 2013
                    • 515
                    • Denver, Colo.
                    Don't try super glue
                    Hey BA 80
                    I bought some jbm replacement diaphrams and per their suggestions used super glue on them. gas melts it and slide glues itself to carb ...on a side note because diaphrams were loose on slides ? I had/have carb problems similar to the ones you were battling with ...since they are on my "El Toro"bike I just live with a bit of stumble ..
                      Just out of morbid curiosity, what exhaust are you running rdmcguy?
                      • rdmcguy
                        • Jul 2013
                        • 515
                        • Denver, Colo.
                        headers
                        Hey Ba 80
                        I have Mac headers ...turnouts ...but more often open headers so to give "El toro" full volume
                          Does the stumble go away when the muffs are off
                            Mine did. Read my "Power loss" thread.
                            • mrtkayak
                              • 17
                              • Woodbridge, VA.
                              Originally posted by hondakid11
                              hahah i thought so . actually i got mine right where it needs to be with the colortune and she still ran a little hang idle until i did a valve job. then she ran smooth. im running k&n pods and open pipes with 45 pilots and 145 mains.
                              When you did the valve. Where did you get the
                              Feeler gauge and if you need shims. Dont know where to
                              Get them.
                              I did checked the carb last night. Taken out the
                              Idling screws and # 1 has broken tip still stuck in there
                              , #2 have a big indentation like maybe previous
                              Owner had broken pin and got it out w a pointed metal. Dont
                              Know what happen bef. I got the bike. Im still stuck w when i start the bike
                              idle is on 4k. Dont know what to do next.
                              If anyone has the same problem bef. Pls reply.
                              I ve had sport bike before. All i have to do ist
                              Bring it to the dealership and boom alldone.
                              79 SF
                              • mack
                                • 2411
                                • Ontario, Canada
                                Negative
                                Do not take it to a dealer! You'll pay big $$$ and the problem will likely persist. We have all been through similar problems so a wealth of knowledge you can draw from is right here.
                                As for the shims, just tell us what you need. A number of us keep a library of them.
                                The problem with with broken idle mixture screw tips is that the holes become somewhat distorted, so the number of turns out from"lightly seated" will be different from factory (and each other). The fact that you just discovered them leads me to believe that your initial carb cleaning effort may have been subpar. Strip them down and remove all the jets and needle jets and do it again.
                                mack
                                79 XS 1100 SF Special
                                HERMES
                                original owner
                                81 XS 1100 LH MNS
                                SPICA
                                78 XS 11E
                                IOTA
                                https://youtu.be/wB5Jfbp6SUc
                                https://youtu.be/RaI3WYHSuWA
                                Frankford, Ont, Canada
                                613-398-6186
