About a month ago I purchased my first motorcycle. The 1980 xs1100 Midnight Special and I love it. The problem I'm having is that there are a few places which are leaking oil and the more I read up on these places the more I feel I made a bad investment.. So some good news of these leaks would be nice, or bad either way information would be much appreciated.
Image (1 of 6)(Crank Case Bearing Housing/Crank Case Cover)
https://drive.google.com/file/d/0BzP...ew?usp=sharing
This Is the main leak that frightens me as I have read that if the leak is from the crank case bearing housing that I may need to take the engine off of the frame and start to take it apart. The other cause of the leak could be the engine crank case cover, and that I hear is an easier fix.
Image (2 of 6)(Also of Crank Case Bearing Housing/Crank Case Cover)
Image (3 of 6)(Zoomed Out)
The next leak I believe to be coming from the cam chain tensioner. I plan on switching this part to the ACCT but would also like a bit of insight into this problem. I noticed that there is also an oil like residue around the header pipe, but as I have read this is rarely the issue, but I'd still like to take it into consideration.
Image (4 of 6)(Cam Chain Tensioner)
Image (5 of 6)(Alternate Angle to Show My Fear of Header Pipe)
I know that air may push the oil upwards from the cam chain tensioner but just from peeking under there; from the naked eye. The possibility of the header pipe having an oil leakage from somewhere still seems possible to me. (For this issue and the others if you desire more photos please let me know, as I would be happy to help you to help me )
Lastly I noticed a leak from the bottom of my stator cover. I did lay it down as this is my first motorcycle (in my defense it was during a u-turn). And I was wondering if thiat alone could be the cause of if there could possibly be an issue with something internal such as a bearing.
Image (6 of 6)(Stator Cover)
For a few other minor leaks I have read that using RTV silicone to seal them up would be sufficient, and if this is the case with any of the problems I've presented that would be nice to know. Anyway I've written enough and I do appreciate any insight into these oil leaks that I am experiencing, thank you.
