1980 XS11 Special - Mayberry Duck Rebuild
    replied
    Mayberry basically complete.....Shifting gears to DEAD DUCK
    Originally posted by HalfCentury
    The entire build is worthy of a magazine cover. The logo on the hard bag is a very nice touch.
    HalfCentury,
    Thanks for the compliment but this bike is far from that level of quality. There are others on this board that do some incredible restorations.
    This bike has come a long way from day I picked it up in Mount Airy (aka Mayberry), North Carolina. With that said, this thread is just about done. There may be another post or two but the heavy lifting is all done. The remainder of my work on Mayberry is generally limited to a few routine repair and maintenance items. I'm also planning to promptly replace the rings as my experience with DEAD DUCK has shown that's a pretty easy move and should provide years of trouble free compression.....
    Today, I fabricated and installed a custom cross support using bits & pieces of the OEM outer support rails. I re-used the mounting tabs to install an additional set of turn signals (yet to be wired). Because this bagger set-up does not allow use of the OEM signals, I'm concerned the mini signals from China are not quite far enough part nor do they attract enough attention. The second set should resolve that issue once wired.
    I decided on the Yamaha Logos to add a little "style" to the bags. Unfortunately, although I have some decent painting skills, my ability to pin-stripe or accent the base paint is much less than admirable. Honestly, I'm pretty horrible with stripes and accent painting. The R1 logos were an easy way to go.
    KURT
    Leave a comment:
  • HalfCentury
    replied
    Leave a comment:
    replied
    Love that shot with little William in the pannier...The bike looks spectacular...Your work is top shelf...
    Leave a comment:
    replied
    Bags Done? - William Approves
    XS Folks,
    I think I have the bags done except for a cross support (to be fabricated) for the rear. My Grandson William approves? Definitely a Yamaha Man!
    William seems ready to take a ride with POP!
    The forward brackets had to be completely cut apart. The flanges on the top and bottom were modified and re-oriented to be accepted on the Special Frame. I also heated and reduced the opening of the curve on the brackets from 13-1/4" down to 12-1/2"..
    Last weekend I got a peek at Mike P's beautiful XS11 Venture and was able to fabricate some extensions to my standard brackets.
    The whole set-up is a combination of self-fabricated pieces and pieces from a standard 11. There isn't another set like this I've been working with Nancy and making sure she would have a comfortable leg & foot area... She's happy with the new set-up.
    I'm going to skip the outer ring(s) and give this a shot exclusively with the back brackets and a cross support in the rear. I believe this is a cleaner look and the bags SHOULD have enough support to prevent damage(s). If there is a problem, I'll switch to the older style fiberglass bags which are certainly much stronger than the newer plastic units.
    Almost ready for EXTENDED traveling!
    KURT
    Leave a comment:
    replied
    Happy wife Happy life Hi to Nancy. Looks fine to me. you had the paint anyway : Do make sure the bolts holding the bracket are tight to prevent any motion. I suspect mine were / are overloaded at times
    Leave a comment:
  • Gmac
    replied
    That makes sense
    It also looks nice!
    Leave a comment:
    replied
    SWMBO Wanted Blue
    I would stay with black for the brackets as they are more of a frame part than a trim part. IMHO. ....Phil
    Phil,
    I had mentioned to SWMBO that I wasn't sure about color on these. I asked "The Guys" and they suggested keeping them black. She said " I thought a little more COLOR might have looked nice"..... Guess what? They got painted body color!
    With the bag installed you can barely see the body color of the brackets.
    Now I have to figure out which OEM pieces will be retained and which pieces will be tossed.
    These CORRECT brackets have a wider "Shelf" to push the bags further off and allow the pull bar & seat removal that the narrower models don't have. They also have a bottom to support the bags. There is still a need for additional support but I will likely toss the outer ring(s).
    KURT
    Leave a comment:
  • Eveready1100
    replied
    Guys, just a suggestion........ Instead of surgery to replace the stud, how about sourcing a couple of mag wheel nuts (lugs?) with suitable thread and barrel thickness which would extend the stud to fit virtually anything you'd want to bolt onto them.
    Leave a comment:
    replied
    Replacing the Shoulder Bolts...
    Kurt:
    I wonder if the stud could be removed, or is it welded?
    Even if we couldn't find a longer one, it wouldn't be hard to make one......
    Mike,
    The bolt is thoroughly welded in place. But that's nothing a drill & die-grinder can't fix. I mentioned this at some time in the past but got some discouragement at the idea. Honestly, it's not that critical a location so being off a 1mm isn't going to change the performance of the rear suspension.
    As you stated, making a comparable replacement shoulder bolt with extended shaft & threads is child's play for anyone with a lathe. Welding it back in place isn't much of a chore either...
    As soon as I get DEAD DUCK back together I'll be all over this modification to Mayberry as I want the bags on SOON!
    KURT
    Leave a comment:
    replied
    Hmmmmm
    Kurt:
    Now you got me thinking.
    It would be really happy day for me if could replace the stud with a longer one.
    PS: The rotation of my previous shock against the plate left a big crescent shaped divot in the plate. That reinforcement seems like a good idea for this reason and others. My fix to avoid a deeper divot is to have a washer between the shock and the plate.
    Leave a comment:
    replied
    Replace with Longer Studs?
    I don't have any thread engagement on the stud that holds the top of the shock and the two bag brackets and the grab bar.
    Mike,
    I see that problem on the horizon as well. When I saw MaximPhil's post I thought.... Gee, I have two full extra sets of the WRONG brackets and could easily double-up that area by sacrificing one of them...BUT, I don't have barely any threads left now! I have rear rack & adjustable backrest installed now but my rear rack does not use the shock tower bolt. I have yet to install the TWO pieces necessary for the bags onto the shock tower.
    I have NOT yet looked at it thoroughly but I'm considering replacing the through bolts with another pair of similar style but longer length...HMMMMMMM.....
    I would think that Yamaha would have provided longer shock bolts for the Venturers?
    KURT
    Leave a comment:
    replied
    Think ahead
    Hi Kurt,
    I would stay with black for the brackets as they are more of a frame part than a trim part. IMHO. The piece that goes on to the top shock mount has broken on both of mine. I would suggest some form of reinforcement in that area.
    I put new aftermarket shocks on the Bagger and now I don't have any thread engagement on the stud that holds the top of the shock and the two bag brackets and the grab bar. You may want to keep an eye on the material thicknesses and the stack-up if you beef up that bracket.
    I'll have to
    (a) machine the shock grommets thinner
    (b) Remove the washers that belong on either side of the shock grommet
    (3) file or mill the grab bar thinner
    ....or some combination of the above
    Leave a comment:
    replied
    Hi Kurt,
    Leave a comment:
    replied
    Finally the RIGHT Parts! Paint Idea?????
    XS Folks,
    Working three project bikes at the same time is difficult to keep focus but I'm getting a lot closer to done with this one... She's running really nice and I was able to drive Mayberry to work the other day (<70 miles round trip).
    The trip allowed me to learn a bit about the bike and I've already addressed a glaring deficiency in the rear brakes.... Replace the Master Cylinder! Done! I've also gotten quite use to the high-quality brakes on DUCK and will quickly upgrade from the stock OEM front master to the 16mm offered by MikesXS which is already on The DUCK.
    Now that Mayberry is running well, it's time to finally get her into BAGGER form. Thanks to some great help from Mike (Radiologsguy) I was able to identify the proper brackets for a Special with the newer style bags.
    I had to weld some extra holes the PO put in them for lights and B.S. but that's now done and the mounts are nearly ready.......
    The differences in the bag supports are significant! The correct brackets have a shelf the bag sits on for support. In addition, the bag extends away from the bike & pull bar by 3.5" vs. 1.75". This will allow the bags to easily clear the pull bar and the back rest supports!
    HERE'S THE MILLION DOLLAR QUESTION:
    I wonder if these support brackets would look good in Body Color (Jetstream Blue Metallic)? Honestly, most of the brackets will be hidden by the bags themselves but this could liven up that dungeon under the rear tire & fender area being a lighter color? I really don't want to mount these them remove them again for painting....
    My bikes are NOT OEM correct in many areas and RESTO-MOD is my preference not RESTORATION. Kinda' hard to imagine these with body color?
    It should not be too over-bearing since much of it will be hidden...
    THOUGHTS?
    Sincerely,
    KURT
    Leave a comment:
    replied
    Guess I just have to put up with her constantly being on my back!
    Kurt
    That's marriage in a nutshell isn't it.
    Leave a comment:
