Clutch Adjusted Wrong?
    • 4015
    So, connecting the dots here . . . My rpm's are higher at 80 mph, and I notice that when I have my clutch pulled-in, shut the bike off, and let-go of the clutch, the bike faintly lurches forward (as-in, you feel a VERY small lurch). We all know that there should be no lurch, right?
    The weird thing is, the clutch friction zone seems normal. I'm wondering is this is a clutch slip or ill-adjusted clutch? Greg said it in the other thread regarding my rpm's being higher, and I DID just replace my clutch cable after it broke . . .
    When you installed the new cable, did you go back and start with the adjustment at the clutch, with the lever end of the cable adjuster all the way in? If not, that would be the start point. If it still slips at speed, then you probably need new clutch springs.
      Ill bearing adjusted would be my suspect Ian, specially having replaced the cable with new. I'm sure you know adjustment STARTS at throw-out behind that right side round cover having full slack at cable lever end.
        • 4015
        The weather is getting dismal here by the day. I'll have to find a day to re-adjust the clutch following the manual.
          One thing about NEW cables, the tend to be a bit short to start but stretch out fairly quickly when you ride a lot.
          Last time I put a new cable on I had a helluva time getting it adjusted so it wouldn't slip the clutch, then after a few days it stretched enough so I couldn't get it in gear or in neutral with the engine running. There is a break in.
            ......Additional good input
              • 4015
              Just an update: re-adjusted the cable about 5:30a in the parking lot before heading into the office. All the way in on the handlebar, then 1/4 turn out at the throw-out. Definitely a different experience now that the cable has stretched a little. We'll see if the rpm's drop once I hit the highway this evening.
                • 4015
                Nope, still same higher rpm's
                  How old are the springs? What BRAND are the springs? how about the clutch plates? These are all related when something like this happens.
                    I just put some new, to this bike anyway, frictions and steels in mine. The frictions that were in mine were the ones that were in that engine when I put it in about 6 years ago. I've been noticing some slight slippage at WOT, I could hear it now that the exhaust is LOUDER.
                    I pulled the cover to replace the 7 year old Barnett springs and figured I would check thickness on the frictions while I was there. They were all JUST above spec. I had another clutch pack on the shelf that had come out of The Green Hornet that had a bolt broken off in it so I checked those plates. They were all at the high end of spec. About .001" thicker than the others so I slapped them in there with some new Barnetts.
                    MAN! What a difference! I gotta be careful on slow corners now or the rear wheel kicks out with too much throttle.
                    Sometimes I just do it for fun....
                      • 4015
                      Barnetts were put-in last year.
                      Only a couple things have changed since my rpm's elevated: went to a '78 mechanical advance and vacuum pod (it was previously a locked-out and modified advance, with a non-attached vacuum line), and I replaced my clutch cable
                        Here we go with the higher RPMs at a given speed because of tuning.....
                        If you are riding a bicycle do you have to pedal FASTER when you feel great to attain a speed that you attained pedaling slower when you weren't feeling so hot? Same diff my friend.
                        • ViperRon
                          • Feb 2011
                          • 1062
                          • Woodstock, VA
                          Test your clutch the hard way get up to about 6 grand in a slight up hill, pull slightly in on clutch full throttle as you dump the clutch and see if it catches or just continues to slip. If it continues to slip the RPM will go to redline pretty easy if it catches you should feel it and the rpms will drop back and then you accelerate. I agree with Greg using the tachometer speed against speedometer is not a test for slippage. All my plates and frictions were above spec in measurement and with Barnett springs and then shims it still slipped now with new frictions there is no slip. My frictions I feel were just deteriorated and would not grip.
                          Rodan
                          1980 G Silverbird
                          1198 Overbore kit
                          Grizzly 660 ACCT
                          Barnett Clutch Springs
                          R1 Clutch Fiber Plates
                          122.5 Main Jets
                          ACCT Mod
                          Mac 4-2 Flare Tips
                          Antivibe Bar ends
                          Rear trunk add-on
