Standard Petcock Alternative
  • mack
    • 2411
    • Ontario, Canada
    For those of you who want to delete the vacumm aspect of the petcocks and reduce the plumbing requirements to the carbs, this is a cheap alternative.
    These have reserve, off and on positions. Here is the required adapter plate.
    You can see that the tank hole is very narrow and a little reaming is required. I used a dremel with a grinding wheel, the following is how that turned out.
    The petcocks come with straight and 90 degree elbows. I used the 90's and turned them to the inside.
    In this photo you can see the reserve tube through the screen.
    This is what it looks like installed. Notice the hex head bolts are countersunk into the adapter plate which leaves a nice clean look. The other thing I like is that these only cost $39.95 can. Which is the same price as the OEM rebuild kits. When these leak in the future, I'll unscrew it from the adapter plate and throw it away and put in a new one. No more vacumm hoses and only one fuel line required per side!
    I got these from MC Distrubuting in Stratford Ontario.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • Bikes
    • Oct 2014
    • 174
    • Coastal Maine
    Looks like the way to go.....of course, I just rebuilt mine a month ago.....doh!....
    But I have aquired an 850 that will need some attention......thanks for the thread.......
    Mark
    1980 xs1100g 3H5.......
    1992 Ducati 907ie
    2001 Moto Guzzi Jackal
      • 4015
      Always good to have alternatives! It's good to see an off position. I've gotten into the habit of shutting my fuel off on my carbs every time I get off the bike (despite rebuilding carbs and petcocks); it's just good insurance.
      Also, if those adapter plates were mine, I'd probs trim them up a little more on the mill, or maybe paint them tank color. They def stick-out, and look aftermarket. However, I've seen pristine bikes, and dirty carb bodies, lol. So, overall they look good.
      Thank you for adding to the parts knowledge bank.
        I'll note that the 3/8" NPT bung on these is standard Harley fare, so that opens up a lot of choices if you go this way. You can buy good quality aftermarket Harley petcocks for as little as $15 (in chrome no less) with your choice of left, right, rear, or down exit outlets depending on the brand. J&P cycle carries a ton of petcocks in all price ranges. I've had zero issues with the cheapies from them....
        • mack
          • 2411
          • Ontario, Canada
          adapter plate
          Nothing in Canada is cheap. If you do go for something else the adapter plate should have the gasket and the holes are 46mm on center.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            Great alternative but I have one little suggestion and I speak from experience. Where you bolt the adapter plate to the tank I did not see where you cleaned the paint off. I do not care what quality paint you have it tends to dissolve in gas and particularly in ethanol added. So I suggest when you get a chance take them off clean the paint and 1st remove chance of leaking and second the paint dissolving loose and getting on the screens. My paint held for a while but did dissolve and cause gas to weep out.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            Barnett Clutch Springs
            R1 Clutch Fiber Plates
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
              Hey Mack,
              Nice work. I was going to ask if you found the petcock/adapter plate listed specifically for the XS11 Standard....but now I think you just found one with the ADAPTER mounting screw spacing at 46mm. BTW do you know what the thread size/pitch the mounting screws are??
              I'm going to be doing a big revamp of Godzilla this winter....I've been tasked by Brent Hoovestal to do so! And RichV has just offered me a SPECIAL frame..."UNBENT" that I can perform a transplant onto so that I can finally get rid of my 2" trail affect! And I will also be looking at repainting my tank, and fixing the petcocks as well. I do have a universal one from PNM that had been given to me years ago, so I will finally be able to see about putting it on.
              • mack
                • 2411
                • Ontario, Canada
                Misc
                Ron- your right, I scored around the adapter and removed the clear coat and paint. This thread was about the petcocks but your right I should have shown that step too.
                TC- the mounting bolts that came with these were M6x24 and fit like a glove. They also had the fiber washers included.The spacing may be different on a special. I'm guessing 32mm.
                Steve- didn't know about the Harley compatibility but nothing from harley up here would be in the $15 US range, not even a key chain. Figure in the $exchange, shipping, duty at the border then our tax on top, $15 us just turned into $80 canadian. I bought a set of fork seals from Denis Kirk a couple years ago and paid $13 US for them on paypal. By the time I had them in my hands, it cost me $77 Canadian.
                Free Trade my Butt!
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  Those are the same kind of petcocks I've got on Betsy. I used to run them with the 90 degree outlets, but I could never get them quite tight enough and wound up changing them out for the straight outlets. It requires a bit longer fuel lines and might be problematic with a stock airbox. With pods there's plenty of room for the lines, and it makes things easier when you've got the tank turned around backwards like when tuning carbs.
                  I'll offer a tip for the washers on the outlets. A cheap paper punch will make a perfect sized hole in an aluminum can for those outlets. You can trim the OD with a pair of scissors and they make dandy crush washers. I used them on my brothers G, which also has those petcocks, and by changing the number of crush washers it allowed me to get the 90's timed right, good and tight, with no leaks.
                  • mack
                    • 2411
                    • Ontario, Canada
                    90's
                    Yes the 90's didn't line up where i wanted them. I used a similar method but i went with adding the second set of supplied fiber washers. I just rubbed them across a sheet of 800 grit sand paper. Checked the fit a couple times until i got a tight fit at the desired angle.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                    • Brak
                      • Apr 2016
                      • 46
                      • Twin Ports
                      I hate to revive a dormant thread, but i didn't see it specifically mentioned...
                      is this applicable to special tanks?
                      the thread title is "Standard Petcock alternative", but Petcocks (plural) was used several time, making me think it might be a special....
                      80 SG
                        There are 2 petcocks on both the standard and the special tank, hence the plural use of the work petcock. The standards have a different mounting bolt separation than the specials so the petcocks are NOT interchangeable. However since this uses a mounting plate adapter it is possible that there is a plate for the specials.
                        • Brak
                          • Apr 2016
                          • 46
                          • Twin Ports
                          ok thanks
                          I didn't realize the standard also had two...
                          80 SG
                          • mack
                            • 2411
                            • Ontario, Canada
                            Mounting plate
                            Yes the plates come with 32, 42 and 46mm on center. I think the special was 32mmoc, but you should check before ordering.
                            mack
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            613-398-6186
                            • Prisoner6
                              • Aug 2013
                              • 1184
                              • Phoenix, AZ
                              Pretty sure the Specials are 34mm on center ...
                              Marco
                              1979 Honda CBX
                              2002 Kawasaki ZRX1200R
                              WE MISS YOU, DON
