Fork cartridge
  • Robsweetland
    • 73
    • Devon,uk
    Fork cartridge
    Does anyone do a cartridge kit? If so are the results good?
    79SF
    xjr ohlins shocks, tarozzi forkbrace, bsa handlebars, bsm exhaust
    How deep are your pockets? I'm pretty sure Traxxion Dynamics can hook you up. Cartridge emulators are far cheaper. IMHO, this is the most worthwhile modification you can make if you ride this motorcycle. I did the emulator/spring upgrade to mine.
    Traxxion Dynamics is proud to introduce the next revolution in motorcycle suspension! The AK-20 Axxion Cartridge Kit. The AK-20 Axxion Cartridge Kit is a complete bolt-in upgrade that replaces the stock ill-performing springs and cartridges with a pair of extremely high-tolerance CNC-machined cartridges, and top quality springs to your needs, weight, and intended use.
    • Robsweetland
      • 73
      • Devon,uk
      Blimey, that's a bit rich for me
      79SF
        Yes. From the same folks I believe you can get custom wound springs and Race-Tech emulators for about $250- $275. It might be a far better value. I'm quite pleased with the performance. It's not the same bike it was before I did it.
