Is the washer/bolt from the end of the countershaft reverse threaded? I can't seem to get the damn thing off and the bolt is starting to round out a bit. Any advise before I really strip it? Thanks.
washer/bolt removal
No, the special washerbase bolt is a regular right hand thread. The torque spec for it is 51 ft-lb so it is going to feel tight. Be sure you are using a good 6-point socket for this, not a 12-point, and a long enough ratchet to do the job. If you can get your hands on a hand-held impact driver, you will get away from the potential of the socket slipping off as you crank away at it.Ken Talbot
