Before I start pulling things apart, I wanted to ask for some advise here. Lord knows there are some smart guys on this site.
My 82 XJ is finally on the road after a frame up rebuild. I'm having trouble with the computerized monitor system. It intermittently stops working properly. There doesn't seem to be a reason, like going over a bump or vibration. It will start flashing the red light, then go through the check of the functions as it is suppose to, but for unknown reasons it will continue to do it over and over again. Sometimes it will not come on at startup as it should. Sometimes the tack goes off momentarily at the same time.
I'm thinking a bad ground, lose or broken wire. Maybe a bad connection in the unit itself. But, If anyone here has had this problem and knows what to look for, please chime in.
Thanks,
Dale
Thanks,
Dale
