Quick rotor question.
    I've lost my my bolt I use to pull my rotor. Just checking it is a 16mm x 1.5 pitch, correct?
    8mm x 1.5. I went to the hardware store and got some grade 8 bolts and lock washers and eliminated those PITA lock thingys that come on there stock.
    Those bolts might be a 1.25 thread pitch too, I don't remember. Just take one to the store with you.
      • 8892
      Originally posted by trbig
      I've lost my bolt I use to pull my rotor. Just checking it is a 16mm x 1.5 pitch, correct?
      Yes it is.
        Sorry Phil but that is NOT a 16mm bolt it's an 8mm. Maybe 16mm long but most definitely not 16mm diameter. The first number is diameter, then thread pitch, THEN length.
        Maybe an 8mm x 1.5 x 16mm
          Actually now I think of it is 1.25 thread.
            • 8892
            BA he means the bolt used to pull the alt. rotor, re-read post #1.
              OK, right. I read it wrong. Sorry
              I got stuck on the title.
                Thanks, Phil.
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  Do you use visual aids while you pull your "rotor"?
                  JW
                  '81 XS1100H - "Enterprise"
                    LOL....I thought he was talking about the BRAKE rotor, the alternator rotor never even crossed my mind.
