In need of valve shims
  • Czekus21
    • 1069
    • Keosauqua (Southeast) Iowa
    I'm in the process of going over my 79sf from head to toe and am now at the valves. I'm in need of 4 (four) shims (250). If anyone can stear me in the right direction that would be very helpfull. If anyone needs my old shims I have 2 (two) 280, and 2 (275). These are from the intake bank.
    S.R.Czekus
    1-big XS patch
    1-small XS/XJ patch
    1-XS/XJ owners pin.
    Just do it !!!!!
    Silly question
    How can an engine need thinner shims at it gets older? Logic says that they should be thicker to compensate for wear. Are you sure you got a correct reading? The only way I can think of it needing thinner shims is that the valves are receding up into the valve seats. I could be wrong. It's happened before, and will happen again. More often than I would like, I'm afraid.
    • ratbyk
      • 994
      • Sooke BC
      Valve Clearance
      John, valve clearances closing up is perfectly normal. Valve face/valve seat wear plus a small amount of valve "tulip-ing" and you start to loose clearances.
      Excessive clearances is a bad thing. You are suffer cam lobe wear. Most likely the cam before the hardened shims.
      Ken/Sooke
      78E Ratbyk
      82 FT500 "lilRat"
      • CA.XSer
        • 189
        • Jerome, ID.
        This site has shims
        CRC
        Gary
        79sf
        78e
        • steelcat
          • Feb 2004
          • 68
          • Elko, NV
          I was able to get shims from my local dealer. He had one in stock & needed to order the rest in. Shims from BMW & Kaw. will also work (just get the right Dia. & thickness). K&L also has shims. There was tha thread on shims a month or so back.
          Ken
          '79 xs1100f
          '79 xs1100sf
          • Czekus21
            • 1069
            Valve shims
            Thanks, I did a valve job on 2 other bikes, (Honda, Kawi), I ordered the shims from my local dealer, they were 5 bucks each. It also took 2 weeks for them to reach me. I don't mind the time but to have my wallet emptied is another story. I'll try the crc site and see what happens
            S.R.Czekus
            1-big XS patch
            1-small XS/XJ patch
            1-XS/XJ owners pin.
            Just do it !!!!!
            • Czekus21
              • 1069
              I went to crc's web site, they have what I need. It's about the same price as my local dealer. o'well the price we must pay to ride
              S.R.Czekus
              1-big XS patch
              1-small XS/XJ patch
              1-XS/XJ owners pin.
              Just do it !!!!!
              • chevy45412001
                • Mar 2003
                • 1412
                • Jacksonville Florida
                shims
                talk to a mechanic at your local shop. I did he said he would trade me one for one.Sounded good to me.
                1982 XJ 1100
                • Czekus21
                  • 1069
                  Thanks for the tip. It just so happens that I know a Lady who works as a liason between the parts and the service dept. I'll see what she can do for me next teus.
                  S.R.Czekus
                  1-big XS patch
                  1-small XS/XJ patch
                  1-XS/XJ owners pin.
                  Just do it !!!!!
                  • srq68
                    • Aug 2003
                    • 125
                    • Sarasota, FL
                    I have an assortment of shimms in my garage, I'll check to see if I have the size you need. I'll trade you one for one...
                    Carpe Diem!
                    1980 XS850G
                    1973 CT70
                    • Czekus21
                      • 1069
                      Thanks for the offer on the shims. I went out and remeasured and redid the math and found that I don't need 250. I need 270. Not as bad as I thought but still needs to be changed. If you have any 270's I'll gladly trade with you.
                      S.R.Czekus
                      1-big XS patch
                      1-small XS/XJ patch
                      1-XS/XJ owners pin.
                      Just do it !!!!!
                      • srq68
                        • Aug 2003
                        • 125
                        • Sarasota, FL
                        Hey, I have two 270s that you need, will trade you for one 275 and one 280.
                        Email me direct at ldguilbert@usa.com
                        Thanks
                        Carpe Diem!
                        1980 XS850G
                        1973 CT70
                        • Czekus21
                          • 1069
                          Thanks for the offer. I sent you an Email with some info. Sooo now it's 2 down and 2 to go.
                          S.R.Czekus
                          1-big XS patch
                          1-small XS/XJ patch
                          1-XS/XJ owners pin.
                          Just do it !!!!!
