Started up, warmed up, smooth idle, a little lower than before.....got busy so three days later, this morning, I jump on and head out to work.....running a little rough at the lowend.......used to be able to put it in 5th at 20 mph and pretty much leave it there.....not now.......above 3 and on the highway smooth and lots a power......putting through town, not so good, rough, gotta keep the revs up a little, not horrible but not as nice...
I'm gonna re sync the carbs and such this weekend but wondering if there's any other post Acct ideas.......thanks...
Folks have reported draining their batteries from just extended synch tuning at idle. You need at least 2500 rpm to reach the minimum engine speed that will provide adequate charging current....and so to run around at 2k with the lights, then brake/turn signals, etc., you're draining your battery and not getting enough voltage to the ignition components to maintain full spark which can also cause misses and such!
. Your issue is likely the pilot circuit. Remove the pilot jets and clean, paying special attention to the teeny tiny sideholes in pilot jets. Use a pointy toothpic and clean them, removing the build-up around circumference of those tiny holes. Keep anything metal away from them!
. Now guess what after installation of carb bank?..........Re-set idle mixtures and re-sync, keeping idle under 800rpm for both those settings. When done, re-set idle mixture at the specified 1100rpm. Go for test ride
