Turn signal removal?
  • pshaw
    • Jan 2004
    • 89
    • Merritt Island, FL
    Hi, I just bought a windshield for my XJ1100 and the directions say I need to attach lower brackets to the headlight bracket. The only place I can see them work is if I install the bracket between the front turn signals and the headlight. My problem is I can't figure out how to remove the shaft (where the turn signals are mounted) and I don't want to break anything by trying to unscrew them if that isn't how they come off. Does anyone know how to remove them? Thanks Phill
  • chevy45412001
    • Mar 2003
    • 1412
    • Jacksonville Florida
    stalk removeal
    pull out the headlight look inside the headlight bucket there are nuts that retain the stalks.Youll figure it out,pretty easy once you see it .
    1982 XJ 1100
    • pshaw
      • Jan 2004
      • 89
      Thanks
      Figured it out. thanks a lot
