Ok. So I've been having an intermittent porblem... IL be riding and everything is fine then the bike just looses power like it's only running on 2 or 3 cylinders... IL pull the clutch in drop rpm and start going again and it fixes itself. First I thought it was the plugs, replaced them. Still does it. Next I replaced the pickup wires from the plug to the pickups. Didn't solve issue. Now here's where I think I'm in trouble. My primary coil leads test 0 ohms. Direct short. Secondary are at 30k ohms...... both. Up until the other day this was intermittent but now it's been constant so I'm assuming my coils are bad? As far as my research has lead me. Am I right? I've never had coil issues so I dont know.
I have brand new battery, and r/r. As well I don't know how to test ignition box.. but figured it that was bad the bike would run at all. It currently runs on idle but won't go past 3k rpm without cutting out and miss firing.
Please let me know what your opinions are.
. 81's and XJ stock coils ohms should be 3ohms. Remember that tesring IS with o power on or to coils
