Fork brace
  • Roncoach70
    • Aug 2015
    • 84
    • Myrtle Beach, SC
    Fork brace
    Does a front fork brace make a noticeable improvement in handling? I put Metzlers on last year, that has made a huge improvement in handling over Dunlaps that I've run for years.
    Thanks for the help.
    79 XS1100SF
    79 XS1100SF parts
    79 RD400F Daytona Special
  • dbeardslee
    • 4385
    • Maineville, OH
    That's a good question - wish I had a good answer. I've got one on Betsy, but I'm not sure about how noticeable the handling improvement is. What I am sure of is that the front ends on these bikes aren't the strongest in the world, and I like having the brace there. I figure every little bit helps.
    • Robsweetland
      • 73
      • Devon,uk
      Tarcozzi
      Fitting one this weekend if it turns up in time? Will let you no.
      79SF
      xjr ohlins shocks, tarozzi forkbrace, bsa handlebars, bsm exhaust
      • Robsweetland
        • 73
        • Devon,uk
        Tarrozzi
        Sorry think it's spelt tarrozzi
        79SF
        • BowlingSS
          • Apr 2015
          • 398
          • Lawrenceville, GA.
          Where does everyone get their fork brace?
          Bill
          Jardine Spaghetti with Harley Mufflers
          • MPittma100
            • Aug 2011
            • 2359
            Fork Brace
            Bill
            From TKAT. Very nice product made by him.
            http://www.tkat.com/forkbrace.html
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • BowlingSS
              • Apr 2015
              • 398
              Do you have to remove the forks for the special? I see the standard is a two piece that clamps around the fork.
              Thanks.
              Bill
              • dbeardslee
                • 4385
                • Maineville, OH
                Thanks.
                Bill
                There are five pieces. You pull the dust caps up, and then there's two half semi circular pieces that go where the dust cap was on each fork. Then you put the center piece on which has kind of oblong holes that allow for a little fudge factor. Tighten 'em down, pull the dust caps back down over the fork brace, and start riding. And no, you don't have to remove the forks. It's a ten minute job.
                This what the standard model looks like. The special type is almost identical, but it's "jacked up" a little to accommodate the front fender -
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  I have an extra TKAT for a Special that never got used. $90 shipped to US.
                  Just PM me if someone needs it.
                  John
                  '81 XS1100H - "Enterprise"
                    Fast from the Past in Atlanta sells Torozzi braces for the standard and Sport. The Sport brace fits the Special. It's and option. I have a Tkat on mine.
                    FWIW, I don't think it makes much difference on a stock front end. I flog mine pretty good and I didn't notice much improvement, but I'm pretty sure there has to be some. Once I modded the forks with heavy springs and emulators, the brace became necessary. The tight front end really loads the forks. It's now part of the package. As always, YMMV.
                    Torozzi
                    • Robsweetland
                      • 73
                      • Devon,uk
                      Tarozzi
                      Just took for a spin and can confirm it's better around the twistys over here with my setup
                      79SF
                        To cover what everyone else has stated........you'll notice the difference with a 5mph left or right turn. Support of upper fork tube IS highly important and eliminates unnecessary wear on bronze bushing at top of fork tube.........this from 34 yrs. of experience, for whatever that's worth. Besides replacement fork tube bushings are NA my friend.
                        • DeanR
                          • Jan 2005
                          • 1499
                          • Finger Lakes NY
                          Tkat made a huge difference on my SG.
                          80 SG
                          81 SH in parts
                          99 ST1100
                          91 ST1100
                            Torozzi
                            Another good optiion that works.
