no compression on #1
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Thoughts? Engine turns over smooth, anything to check before I just go and rip the head off?
    1979 xs1100 Special -
    My Bike:
    [link is broken]
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    so I just came in from head removal, and the #1 exhaust valve is clearly bent. With the head off you can look in the exhaust port and see light around about 1/2 the diameter of the valve.
    Looks like the PO must have bent it on re-assembly as there is a brand new head gasket and the inside of the head is all cleaned up.
    So 2 choices, I have the siezed up motor - I can take the whole head and move it over.
    Or I could just remove the 1 exhaust valve from the seized up motor head and move it over. Benefit being that I suspect the old head had leaky valve seals, and these should be new in the other head.
    Any suggestions appreciated!
    My Bike:
    [link is broken]
    • dbeardslee
      • 4385
      • Maineville, OH
      I'd probably just move the valve over if you think the seals are in better shape - assuming the bent valve will move back far enough to get the keepers off. If you can't get the bent valve out relatively easily, I'd probably lap the valves and put new seals on the other head, and then install it.
      • dbeardslee
        • 4385
        • Maineville, OH
        I'd take a real good look at the valve guide on the bent valve too. I don't think bending a valve would damage the guide... but I'd check it anyway. JAT
          • 9980
          It should come out fairly easily. Just swap out the valve ( getting the face ground on the used one would be a good idea) and be sure and line up ALL the timing marks BEFORE tightening the cam bearings psyco.
          It was never run, allegedly, so the guide should be fine.
            • 9980
            Hmmm.......something SERIOUSLY wrong with this site.
            If it was .org I could blame Harry's cat.
              Hey Greg,
              I deleted your double post. Sometimes the site just hangs a while, and then if you hit the submit button again, it created another copy!?
              • MPittma100
                • Aug 2011
                • 2359
                Procedure
                Procedure wise with 0 compression, you should leak test the hole to see what is causing the loss. In this case being the exhaust valve, first check would be lash.
                Your signature indicates 1981. Make sure that the spare head is 1980 or 1981 as earlier valves are different. The 1980-1981 exhaust valves are no longer offered by Yamaha.
                Not a real good idea to go through all of the trouble to R&R a cylinder head unless you know that the condition is excellent.
                When assembled, turn engine over by hand to confirm correct valve timing.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
