Battery Tender Jr.
  • dbeardslee
    • 4385
    • Maineville, OH
    Battery Tender Jr.
    I just put a new battery in Betsy about two weeks ago, and I want to get some life out of this one, so I bought a Battery Tender Jr. I hooked it up and left it on 'till I got a solid green light, and then disconnected it. That was about five days ago, and I figured since I'm riding her regularly I probably wouldn't need the battery tender 'till the weather gets cold.
    I didn't stop to think about the way I ride, and the way the battery charges. I make a lot of short trips, and I do a fair amount of puttering around the neighborhood at low rpms. Just for grins I connected the battery tender last night, and to my surprise it took several hours for it to reach a full charge. I guess all those short trips and puttering was pulling the battery down more than I thought. Now I'm thinkin' I'll leave that battery tender on her all the time.
  • alaskey2
    • Apr 2014
    • 271
    • 60940
    I was told that it takes about 20 minutes of riding to recharge the drain of starting the bike. Since I live in the city and most of my rides are quick I put on an xs850 kickstart lever and use that about 90% of the time.
    78 E
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      I have Battery Tender Juniors on three bikes, basically all the time when parked in the garage, all year long. Never a problem.
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • dbeardslee
        • 4385
        • Maineville, OH
        I've got an 850 kick starter, but I'm faaaaar to lazy to use it. The cool thing about the BT Jr is that it comes with a ring connector wire that bolts on the battery terminals. All I have to do is remove the side cover and plug it in. It also comes with an alligator clip wire if you want to charge something else.
        In use...
        Not in use...
        • dbeardslee
          • 4385
          • Maineville, OH
          I'm lovin' this thing. I tried a cheap Sportsman's Guide float charger that my brother gave me, but that put out 1.25 amps and the red light never went out. I could see bubbles coming up inside the battery and I was afraid it was going to boil the acid out, so I gave it back to him. The BT Jr figures out what it's connected to when you first plug it in, and it doesn't cause bubbles to come up in the battery. Plus it's only .75 amps, which seems much more appropriate for a motorcycle battery. I figure if I get two or three years out of a battery instead of my normal one or two years, it will more than pay for itself.
            +1, me too.
            Cost:
            High: 20 minutes of riding above 2,000 RPM @ $3 to $4/gallon.
            Median: ~20 cents/KWh for however long the battery charger decides to run.
            Free: Kicker
            You've seen That Guy pushing his bike and trying to get it started with a dead battery.
            Don't be That Guy.
              • 2117
              If you have a kick starter It doesn't matter,If you dont have enough voltage the TCI unit wont work anyway.Kick all you want you are not saving.
              • dbeardslee
                • 4385
                • Maineville, OH
                I thought what they were saying was they use the kick starter instead of the electric to keep from draining the battery to begin with. Which actually makes some sense to me.
                I just made a run to three different stores, for a total of four electric starts and a total of about fifteen or twenty minutes run time. I plugged in the BT Jr on my return and the light stayed red for about 5 minutes, and it's now on blinking green which means it's got better than an 80% charge. I'll see how long it takes to go to solid green, just for grins.
                I've got the emergency kick starter on mine, but I'm not going to use it unless I absolutely have too. And if I've got a hill handy, I'll try a roll start before I do that.
                  • 2117
                  From what i have read on here if the battery voltage gets too low-the kick-start wont work.
                  • dbeardslee
                    • 4385
                    • Maineville, OH
                    I totally agree with you on that. But IIRC it's way low voltage - like 12.2v or somewhere around there.
                    • dbeardslee
                      • 4385
                      • Maineville, OH
                      Okay - it's been hooked up for less than forty minutes and the light is solid green, which means it's between 100 and 103% of a full charge, and the charger is in float mode. I'm likin' that thing a LOT.
                      • BowlingSS
                        • Apr 2015
                        • 398
                        • Lawrenceville, GA.
                        Where did everyone get the Battery Tender Jr?
                        Bill
                        Jardine Spaghetti with Harley Mufflers
                        • dbeardslee
                          • 4385
                          • Maineville, OH
                          I got mine at Walmart. Which was a mistake. They advertise them online for $25, but when I got up to the store it was marked $35. Since I was standing right in front of it, I went ahead and bit the bullet. I could have ordered it from Amazon, with an additional 12.5' extension cord that goes between the charger and the ring connector wire, and a spare fuse for the inline fuses for the same money. Free shipping on Amazon for orders over $35 - $25 for the BT Jr, $9 and change for the extension cord, and a few bucks for the fuses. Or however you want to get it over $35. I like it when I don't have to pay sales tax or shipping.
                          Or they make a 25' extension cord for around $15, which would give you a total of 37' between the charger and the battery to work with.
                            12.what volts and the TCI won't work? You bumped your head, Scooter, have you ever kick started an XS11? One kick and it starts, if it takes any more there is something wrong with the bike.
                            Like the infamous witch, the battery has to be 'really, truly dead' for the kicker or a push start not to work, like down below 10V type dead even with the lighting fuses unplugged, which is getting into 'Walking Dead' territory because any lower and you will be walking.
                              • 1262
                              • Peachtree City, Georgia.
                              DITTO! I have FIVE plugged in right now (CT70 [6volt], XJ550 Maxim, Z-28, Trans Am, XS11). All plugged in whenever they are not being driven. The analog clocks in my old cars will KILL the battery in about a week so I just keep 'em plugged in 24/7.
                              Kurt
                              1982 - CBX1000 - Honda
