So what do you get when you cross an XS11 with an elephant? A motorcycle with a trunk, of course. And I just installed one on Betsy, which leaves me with a second key to keep track of. I don't like to have keys flipping around in the breeze as it tends to chew up the handlebar clamp (even though some PO up the line already did a pretty good job of that.) So I drilled a 1/8" hole through the new trunk key, and pop riveted it to the ignition key. Now both keys are permanently attached together, and when I get around to repainting the handlebar clamp I won't have a key knocking the paint back off.
