The Rod bearings are good, amazingly good. Trbig is right, the Rods don't seem to wear as much as the Mains (unless there's something else wrong) but I'm double-checking everything while the case halves, covers, and gears take a long bath in #2 Diesel.
I know better than to trust something that looks good by eye so I'll mic' the crank and the shells and check the oil clearances with Plastigauge to make sure they really are good. Which reminds me, I have to go buy some Plastigauge or this is going nowhere.
While the engine is open I'm replacing the sanded Cam and Primary chains. Except for the custom-cut 2nd Gear Wheel and its shims, everything else is getting replaced with the low-mileage parts from my wrecked XJ engine and be done with it. I love parts bikes, especially parts bikes' engine parts that haven't been drenched with sand.
Frank's stein is filling up!
Along with the '80 XS850G Final Drive this will give Columbo a 1978-79-80-81-82 XS1100EFGLHJ engine. It's still the original '80G engine case and serial number to match the frame but it will have '78E pistons, a '79F cylinder head, the crankshaft and matching rods from a '81LH, and the primary shaft and the transmission from a '82J.
YouTube: Trigger's Broom... or was it Granville's?! 0:57
I suppose that while I have everything apart I should clean and paint the engine before I put it back together so it'll look like new again and clash with its owner and with everything else on the bike except for the new B&H seat cover.
(Sold back to Maximan)
