I picked up this '81SH from Craigslist at the beginning of the year in January and am finally getting to work on it. Since then, I have also picked up a titled '79SF with fire damage that came paired with a reasonably complete '79F parts bike. I'm not sure yet what my plans are for the '79SF...
This '81SH has ~95k miles on it and may have been parked for a couple of seasons outside.
So far I have:
After cleaning the carbs, I found I didn't have spark. I found one pickup coil was testing 4 MOhm, the other tested open, so swapped in another good set of pickup coils.
At this point I have fired up the bike to a pretty loud clatter in the top end. On the bright side, this exhaust sounds really good otherwise! I pulled the valve cover and there is evidence that the cam chain has hit the underside of the valve cover. The tensioner had maybe 1 mm of movement left. Unfortunately, I didn't pull the tensioner before adjusting it so I have no idea if it picked up any slack.
Because the tensioner plunger did have a tiny bit of adjustment left, I think I will go ahead with buttoning it up and starting it again and try to get a better idea where the noise is coming from, if it still exists. I haven't ruled out an exhaust leak yet. I definitely need to replace the cam chain and add an ACCT.
Basically, I have a bike with 95k miles and an unknown history. I'm excited to see this start to come together as it is surprisingly in pretty good cosmetic condition.
So far I have:
- Changed oil
- Checked compression
- Cleaned carbs - replaced diaphragms with JBM Industries diaphragms
- Replaced pickup coils (1 bad pickup coil, other had 2 broken wires)
- Replaced fuse block (used my spare, new spare has been ordered from TC!)
- Checked valve clearances (adjusted a couple, still need some shims)
	 THey are getting harder to find as well as $$.
