Kick starter
  • JeffH4547
    • Jul 2015
    • 9
    • Ovid, michigan
    Kick starter
    I have 1979 Yamaha XS1100SF. I see the shaft for the kick starter under a plastic cap. Handy thing to have if battery goes dead. Where is the kick starter lever? Were they sold with the bikes or seperatly? How easy are they to find now?
    JeffH
    XS11
    • 1249
    • Peachtree City, Georgia.
    Kick Start
    Jeff,
    Your bike should have had one from the factory. It should be stored just behind the motor on the side where it would attach to the motor. They use a wing-nut and cover. It's kinda stored under the battery.
    If you don't have one, contact member ANDREAS. He probably has one at a reasonable price. That's where I got mine
    As you mentioned, it's only for emergency use not for daily use. I've been trying to add one to my 80SG (for emergency use only). The majority of the parts were removed in 80 as the kick start was no longer offered. I need an internal ratchet gear and mine will be all set.......
    KURT
    • Gmac
      • Aug 2014
      • 256
      • Huntsville, AL.
      It is also
      A pain in the leg to use as it does not fold out of the way and will poke you as you ride back to the barn. DAMHIK
      79 SF & 80 LG MNS
      73 & 74 RD 350's
      73 Honda CL 450
      Graveyard - '81 XS850 Special
      • mack
        • 2411
        • Ontario, Canada
        If you
        find the wratchet gear and install it, also buy a 78/79 battery box. It has the built in clips for storage after use. Then the lever won't be a pain in the leg when getting back to the barn. The rubber cap is whats hard to find.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • Prisoner6
          • Aug 2013
          • 1184
          • Phoenix, AZ
          Jeff,
          If your SF still has the kick-starter lever tucked away, you'll be able to reach behind that wing-nutted cover and feel the lever ...
          It runs along the underside of the frame cross-member that is just in front of the rear master cylinder.
          If not, then (as Kurt suggested) contact Andreas (he's our resident "go-to" parts guy) on his profile page linked below:
          andreashweiss
          Once there, click on the yellow "Contact Info" tab, then send him a Private Message detailing what you need.
          Marco
          1979 Honda CBX
          2002 Kawasaki ZRX1200R
          WE MISS YOU, DON
          • MPittma100
            • Aug 2011
            • 2359
            Kick Start
            JeffH
            The kick start would be a really good idea if the bike had a magneto ignition. When the battery goes dead on the XS11s, there is usually not enough voltage to fire the ignition. Other than buying a missing lever to keep it original, the kick start function is pretty much a novelty item.
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              • 2138
              Me too
              Kurt:
              Thanks for the picture. (And thanks, Marco, for the description)
              I have procured the kick-lever, the wing nut and plastic cover, but I never looked to figure out how to attach them.
              • Prisoner6
                • Aug 2013
                • 1184
                • Phoenix, AZ
                ... When the battery goes dead on the XS11s, there is usually not enough voltage to fire the ignition.
                That's true, Mike ...
                If the battery is completely dead ... no kick start.
                But the kick-starter will work if the starter flakes out on you.
                Marco
                1979 Honda CBX
                WE MISS YOU, DON
                • mack
                  • 2411
                  • Ontario, Canada
                  oops
                  I mis spoke. The actual bracket to hold the kick lever is under the left battery box retaining flange. Not sure if 80/81 frames kept them
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
