Question Regarding "High RPM" Sync
    • 3954
    So, the GSX1100 uses flat-side CV carbs. Not that it makes a difference, but just a note. Forum members on there are relatively young in age (first-time bike owners), so the collective knowledge does not have the experience like our forum.
    So, there are literally 12 pages of threads regarding syncing the carbs. However, contrary to our "low idle" sync, their recommendation is for a higher idle sync. Their response as-to why:
    "it is mid point on the idle circuit. it has a higher vacuum reading, making the sync more accurate as rpm will fall or rise as the adjustment is made. Too low of an rpm and the readings are too low to get even precisely and could stall the bike. There are many ways to do a sync, I sure. This is the way I and many Kat owners do a sync with a column type sync tool, which is another reason, they need more vac to pull to mid point on the scale."
    • 7819
    What I do is adjust the sync at about 1000 to 1200 RPM, and then rev it up to 4,500RPM and let it settle then check to see that all 4 are still in line. The low RPM sync is NEEDED to get the bikes to run as they should, and the midrange sync is a sanity check on the overall condition of the carb sync.
      Agreed! Should still be close in mid to higher rpm.
      If they are having that much trouble getting a vac reading down low then they must have other issues.
        Originally posted by natemoen
        ... If they are having that much trouble getting a vac reading down low then they must have other issues.
        +1! What Nate and Ray said!
