Guess
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Guess
    what I'm dealing with. WIN A PRIZE !
    I've got my Horse SF running really great for about 30 min., then it smells hot and starts sputtering on take off from a stop but once moving runs fine again until taking off from another stop. Have not ridden far from home since I discovered this so as soon as I notice it I head for home. Tried a few times just to make sure it was really happening.
    Thanks ! Don'e
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • mack
    • 2411
    • Ontario, Canada
    What do the plugs
    look like? Are they looking like they are running lean, hot, any bridge debris?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Fouled
      they are all dark but 3 is carbon more. Bad pic I know but the sun is just right. Checked the fuel level in all carbs and 3 is 2mm higher than the rest.
      Thanks ! Don'e
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • MPittma100
        • Aug 2011
        • 2359
        Plug Reading
        Thanks ! Don'e
        The darker plug in your picture is number 2 cylinder as I see it. Point is - that darker (sooty black) plug indicates an over rich condition or poor ignition in that cylinder. If that plug was in the cylinder with the higher float level, test ride again after float adjustment and recheck plugs.
        None of the other plugs indicate a too lean condition which would tend to cause excessive heat. A better picture would help.
        Some things to check would be your spark caps where they go into the plug wires for good connection and verify that the pick up coil wires are in tact.
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          Hey Done,
          IF it's running rich, then it should be running a little cooler than if running lean!? If the bike is getting HOT after running a while (30 minutes) and I'm assuming you mean actually RIDING it, yet the carbs are tuned rich, then there's something else making it hot. Either the oil isn't circulating like it should....or perhaps the actual TIMING is not advancing enough so it's running "retarded" , which from my car tuning days will cause an engine to run hotter!?
            Running really rich, you'll have some unburned fuel burning in your exhaust and getting it really hot. Nearly as hot as a lean condition. Initially, the bike likes a rich condition.. much like having the choke (Enrichener) on.
            I'm guessing floats not seating well. At low RPM, it's flooding. During higher rpm, there's enough air flow to burn the extra fuel decently, but it's still going to get your pipes pretty hot, and any oil on those is going to get burned. If you had an infrared gun, I'm betting the motor isn't overheating, but your pipes are.
            • ViperRon
              • Feb 2011
              • 1062
              • Woodstock, VA
              What is the compression on that number 2 cylinder???
              Rodan
              1980 G Silverbird
              1198 Overbore kit
              Grizzly 660 ACCT
              Barnett Clutch Springs
              R1 Clutch Fiber Plates
              122.5 Main Jets
              ACCT Mod
              Mac 4-2 Flare Tips
              Antivibe Bar ends
              Rear trunk add-on
              • olinrj
                • Jul 2015
                • 47
                • Greenfield, Wisconsin
                Good to see you've got the SF running Don'e! Unfortunately, my diagnostic skills are not that advanced so I cannot put forward an opinion on the stumble.
                78 E
                  • 9980
                  Looks like and sounds like carb issues. Are you running Mikuni Jets? Pilots and mains?
                  I started out with an issue like that and found it was after market jets causing it,
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    jets
                    I know I left this hanging for some time, virile bronchitis, cramps in my lower front chest, (bottom of the ribs) got me depressed.
                    New meds and better !
                    In the last week adjusted floats to min. changed out 42.5 pilots for a spare set of 42.5 I had, needed adjustment again of course.
                    Originally #3 in the plug photo only wanted 3/4 turns out (plugs are bassackwards in photo) the rest about 1 3/4.
                    So now it does not stutter after 1/2 hour or more of riding, goes like a dragster, ( maybe been off to long ?) will do a plug check, these are left to right.
                    Some other probs came up I think from sitting so long, I may address those in another thread, kind of interesting.
                    Thanks you guys and girls ! };-)
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                    • mack
                      • 2411
                      • Ontario, Canada
                      lookiing
                      at just the tips really can't tell us much nowdays since fuel has changed. What I can see is that the bridges look pretty good so the timing seems fine. If it was my bike I'd richen the idle a bit and do a chop test to check the pilot and main jetting. The pilot is mid point down the outside wall of the electrode and the main should show a distinct darker ring at the very bottom.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        The fuel I'm using is from 20-40 mi. from here, no ethanol, with some MMO added. Will do some more testing.
                        The rest of the bikes, I'll not be able to get to them. If anyone is interested PM me !
                        Thanks, Don
                        Originally posted by mack
                        at just the tips really can't tell us much now days since fuel has changed. What I can see is that the bridges look pretty good so the timing seems fine. If it was my bike I'd richen the idle a bit and do a chop test to check the pilot and main jetting. The pilot is mid point down the outside wall of the electrode and the main should show a distinct darker ring at the very bottom.
                        76 XS650 C ROADSTER
                        80 XS 1100 SG
