Where to buy Jets online?
Jets
jetsrus.com is the place to go. But do buy the Mikuni (more expensive) jets ONLY.
You should start out with the stock sizes of main and pilots jets. Make sure to be very specific with float height setting. Be sure that you do not have any needle valves (needle and seat) leaking in any of the carbs. Install inline fuel filters. Again, use MIKUNI JETS, NEEDLE VALVES, and any other carb part needs to be MIKUNI ONLY! The carb kits that are available online do not have Mikuni parts in them.
When you have everything dialed in, you should get no less than 30 mpg and up to 40 mpg.1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Don't know why you would buy from jetsrus.com at $6.09 each when bikebandit has them at $10.76 for 4. And shipping is a tad cheaper. And yes they are Mikuni.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
79 SF parts bike.Comment
