The 'legs' have to be there on the starfish washer or its replacement.
The shift pawl pins do move between the 'legs' during the up/down shift indexing.
Some of the causes of the broken starfish washer:
Upshifting without the clutch or just fast upshifting.
The shift drum tries to slide out of the case to the left as it rotates and positions the shift forks during upshifts. The lateral movement's not bad during a "normal" upshift when the gears aren't under load. When they're loaded, the shift drum has to force the shift forks to move gears on the transmission abacus/Main Axle Assesmbly (Input Shaft)/Drive Axle (Output Shaft). If the whole shift drum assembly is in good shape and it just pushed out to far during one really 'hard' upshift, that's when you can replace the washer and it won't just break the next time you go riding. If the drum assembly's worn, it'll keep moving out of the case and the shift pawl will slice the legs off the starfish like a sushi chef.
What wears?
The left-hand shift drum bearing race wears and can't hold the shift drum.
The shift drum retaining dowel pin can be worn or bent.
Bent or worn shift forks, they make the shift drum work harder to shift gears.
The shift fork shaft/oil pump drive gear shaft can be bent. The oil pump gear retaining clip can be worn or taking a time out in the oil pan because it was installed backwards, bevel side out, on the shift fork shaft.
When the shift pawl wears out, it won't sit up straight on its seat when you shift and it snags the starfish washer, usually during the 4th-to-5th gear upshift. That can leave the bike stuck in 5th gear because if you're traveling, it might be a while before you think about downshifting and the 4th gear shift drum pin will eventually take a swan dive out of the drum and join that oil pump drive gear retaining clip for a swim in the oil pan.
What wears?
