So I had to remove my rear fender and disconnect my tail light/flashers to change my rear tire. The P/o replaced the stock fender and lights with a harley one making it necessary to remove it during a tire change. and the wiring the P/o had put together was a little jankey so I began to replace the 16awg wire with 14awg wire. After I hooked up the tail light I wanted to check to make sure the wiring was working so I connected the tail light exactly how it had been when I disconnected it. nothing happen so I started experimenting thinking that maybe I mis wrote the wire routing when I disconnected it. when I connected the taillight "black" wire to either of the flashers wires from the bike, the taillight and opposing light would work perfectly.
Video of issue here
https://www.youtube.com/watch?v=tLjNxmwBOBs
So I'm thinking the issue is the black wire coming from the bike but I don't quite understand what would make the wire all of a sudden stop working. it was working perfectly before I removed it for the tire change.
Video of issue here
