Intake Valve O-Rings?
    • 1241
    • Peachtree City, Georgia.
    XS Folks,
    Quick question.....
    I'm rebuilding my XS11 head and the full engine gasket kit includes eight small O-rings (12mm +/-). The kit came with NO instructions and I can not determine where the heck these are supposed to be used? I checked on-line and one of the pages I found refers to these as: Kit Includes "(8) Intake valve O-rings"
    I thought they might be for the base of the head bolt shafts but there are 12 of those. I have not pulled the Jugs so I don't know it there are any down there anyway. I've checked every page of the Clymer manual related to; head, valves, etc. can't find a thing.
    The only thing on this motor there are precisely eight(8) of are the valves. Where the devil are these supposed to go? Mistaken O-rings for some other motor?
    I have the eight(8) valve "SEALS" and am about to install those and get the valves all put back in......
    Where in the world do these eight(8) 12mm (+/-) O-rings belong?
    Thanks a bunch,
    KURT
  • somesuch
    • Jun 2007
    • 145
    • San Jose CA
    for the valve guides before you press them?
      • 1241
      Maybe?
      Somesuch,
      I'm thinking the valve guide needs to go metal-to-metal with a press or shrink fit into the head. I can't pull those at home anyway. They're also referred to as "Intake Valve O-Rings". If that is true, and INTAKE is a good word, I'd only need four not eight if it had something to do with the stem or guide on the intake side.
      Still baffled......
      Kurt
      • Old Red
        • Jul 2012
        • 290
        • Greenville, NC
        No o-rings goes on the valves, just the valve stem oil seal.
        80SG, 81SH, 80 standard parts bike, 81SH parts bike
        and new to me 78 standard dresser
        • mack
          • 2411
          • Ontario, Canada
          o rings
          I've never found a location for them either.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • BowlingSS
            • Apr 2015
            • 398
            • Lawrenceville, GA.
            I am not sure why they put them O-rings in the kit. Normally you do not replaced the valve guides. If I rem from long ago each valve guide has a o-ring before pressing them in.
            Bill
            • somesuch
              • Jun 2007
              • 145
              • San Jose CA
              They are for the valve guides, I guess I should not phrase my answer as a question next time
                • 1241
                O-rings.....
                Bill
                Bill & XS Guys,
                Thank you for the replies. I guess valve guides are the only place that would require eight(8) identical O-rings of this size. I'm certainly not capable of (or willing to try) pulling guides at home. Strangely, they provide O-rings for the valve guides but no: new crush washers for the oil line, no O-ring for the CCT, no intake gaskets (made my own), etc. Sort of a crappy "Full Engine Kit" but the kit was basically the cost some are asking for just a head gasket so I guess it's like I got a head gasket and all the rest of the gaskets provided for free.
                I have all the new stem seals in, the valves lapped, and everything re-assembled, just waiting on a replacement head gasket as the one in the kit was damaged in shipping.
                Thanks again,
                Kurt
                • mack
                  • 2411
                  • Ontario, Canada
                  You checked
                  the valve/seat seal with varsol to ensure no leaks right?
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
