Assy Fuse Block
  • Assy Fuse Block
    I am installing the new fuse holder and have a special horn that was already installed and wanted to remove that assy fuse block. Is there a purpose for it?
    The horn has a relay I wanted to mount in that spot. The other owner had it stuffed under the seat, not mounted.
    I have the four fuse lines moved and also want to move the main fuse since I have one open spot. Any thing I should look out for? That fuse is on the left side of the bike. Why did Yamaha put it on a different side?
    Thanks.
    Bill
    I am going to remove it. I do not see a reason for it.
    Bill
      I am going to remove it. I do not see a reason for it. I can always put it back.
      Bill
        Sounds like you made your decision. Only reason that fuse is located where it is, is because of accessability.
          I got a second main fuse holder for $2, cut the plug off and ran new wires to the spade fuse in the new block. The old one is still there, and can be hooked up if I ever need/want to.
          Steve R
          '80 SG
          "Fred" -- TC fuse box, stock airbox/exhaust/jets, SS brake lines, Windjammer V fairing, Cibie headlight lens, TKAT fork brace, Showa rear shocks, MikesXS emulators
          Former bikes:
          1973 Yamaha 125 Enduro (brother's but I 'borrowed' it a lot, usually after midnight)
          1978 XS400E Red
          1981 XS850 Special (Stingo)
            That was a great idea but I have used all six in the block. I moved the main fuse and a special horn in the block. I tested it last night and my Head does not work. I need to go out and check it out today.
            Bill
              Post a pic when you're done. I have a FIAMM set and relay waiting to go in and wondering where to put the relay.
              Steve R
              '80 SG
              Former bikes:
              1978 XS400E Red
                Hope this came out OK. If I had to do it again I would use straight connectors on the top and 90 ones on the bottom.
                Sorry about the picture being turned.
                Bill
                  Bill
                  I replaced the connectors for the Head but this was operator error. My other bike lights come on when the key is on. I just realized this one has to be running before the light come on. We live and learn.
                  Bill
