Help broken/frozen exhaust manifold bolt (with pics)
  • OMCC
    • May 2014
    • 73
    I was taking off the exhaust to patch some holes and one of my bolt heads snapped clean off another two of the heads spun off.
    so I have three manifold bolts stuck in the block total one snaped off and two whole. so far I've tried, cutting a slot and using an impact driver, heating with a small butane torch, and crc freeze off. The broken bolt has no threads the other two are just very rusty
    • How do I get these bolts out?
    • Being that I'm not experienced in removing frozen bolts is it best to bring it to a shop and have them remove the bolts?
    • What would it cost to have those bolts removed at a shop?
    • I bought new bolts but haven't been able to find the nuts what is a suitable replacement?
    • I also snapped one of the crossover circle clamps what is a suitable replacement for those?
    • anyone in the Long island area interested in helping get these damn things out?
    • Is there any way i could still drive it to a shop without that one bolt secured?(shop is roughly a mile or two away)
    Thanks!
    79 F Bobber/Cafe Hybrid
    Rasputin on Carburators:
    "It is just a mechanical beast that defies logic."
    Here you go!
    Broken Stud Removal Techniques.mp4
    • OMCC
      • May 2014
      • 73
      do you know what that tool is called and where I could get one?
        Titan Stud Puller - 3/8in. Drive, Model 16023
        http://www.northerntool.com/shop/too...5363_200385363
          • 4015
          That's a sexy tool. Will be adding that to my tool box.
            • 2104
            That what she said !!!
            • BowlingSS
              • Apr 2015
              • 398
              • Lawrenceville, GA.
              I want one of those..
              Bill
              Jardine Spaghetti with Harley Mufflers
              • somesuch
                • Jun 2007
                • 145
                • San Jose CA
                In places that have good access, you can just us the drill chuck...most of the time for the small studs (6mm or so) Milwaukee cordless has plenty of torque, sometimes I help it along by twisting the chuck by hand as well.
                I also use it to remove dowel pins/etc. works great without damaging them if you do not over tighten the chuck.
                • OMCC
                  • May 2014
                  • 73
                  I tried the tool suggested in this post and it only made the situation worse now I have two broken studs. Going to try and drill it out today but probably destined for the shop tomorrow.
                  • TomB
                    • 967
                    • Cumbria, UK
                    For your short broken exhaust stud I'd slide a bigger nut over the stud and weld it on, the heat helps release the stud from the ali head and the nut allows a socket to turn it. IF you access to a welder.
                    Tom
                    • Tenorman
                      • Oct 2013
                      • 70
                      • Butler, Penn.
                      Just a thought...
                      Just a thought...
                      While you have plenty of room to work, give a thought to changing the old style camshaft chain tensioner to an automatic one...
                      The stock one is not very reliable and if it should fail while the engine is running, it could turn into a mess...
                      Just a thought...
                      The Tenorman
                      Bikes that I have owned and enjoyed...
                      1964 Allstate 250
                      1970 Yamaha DT1
                      1959 Mobylette
                      1970 Yamaha JT1
                      1995 Suzuki 80
                      1978 Yamaha XS650
                      1980 Yamaha XS1100LG
                      2005 BMW R1150R
                      • OMCC
                        • May 2014
                        • 73
                        I actually bought one a while ago and havent installed it might be a good idea. The shop want to charge me between 2-300 just to get the manifold bolts out out Im a litle worried about taking the cylinder cover off and snapping more bolts.
