extra ground wire
  • kevxs
    • Apr 2009
    • 353
    • toronto
    extra ground wire
    I'm interested in running an extra ground wire from the regulator/rectifier to the battery or the frame. I've read a couple guys on here that says it can help cure a bouncy tach and just improve reliability. My question is where to I attach the wire to on the regulator and should I run it to the battery or to where the battery attaches to the frame?
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
    What would keep you from polishing up the three already existing ground wires attached to regulator mount bolt, and bolt mounting surface of regulator? Your above mentioned grounding locations may need a spiffin' up also.
    Would even consider removing and cleaning internals of the KILL switch.......and ALL plugins' behind fuse panel, ect....ect.....ect..
      • 3954
      Over on the GS forum, a single ground source is stressed.
        Hmmmm........didn't know that the volts divided, searching out additional grounds.
          • 9981
          The bouncy tach is due to the 35 year old electrical components inside. I've never had one that worked perfectly.
          Yamaha should have never built one that ran off of the alternator pulses. Bad idea.
            Hmmmm......The Bentley's tach has not so much as wavered........guess I only got two more yrs. before it makes a liar outa' me.
              • 9981
              Have you checked the accuracy? I have one that doesn't bounce but it kinda flattens out around 4 - 5 k.
                I would like to know their reasoning.
                • MPittma100
                  • Aug 2011
                  • 2359
                  Extra Ground
                  Any ground other than a direct battery ground is a poor ground.
                  Run another wire from the regulator ground directly to the battery. You should improve other chassis grounds in this manner.
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                    • 7818
                    Going into what I work on every day, a single ground is best in a perfect world. The connections, wires, crimps, and all are getting old on the bike, so another wire would not hurt. I put a ground wire, #8, directly from the negative of the battery to the engine. I also cleaned up ALL the ground connections on the Quail bike, and I still have a few problems to work out.
                    Grounds NOT all going to one location will give you what is known as a ground loop. What this does to the bike is drop the voltage potential in some of the circuits. In the radio's I work on, it could result in 200V between a case and the earth ground. Yeah, it has been done, and there are people with the scars from the electrical burn to show it.
                    Yamaha uses one of the bolts on the reg/rec as a main ground for the harness. If you put in a wire, go from that bolt to the negative on the battery. But, don't forget to check the engine case to the battery. With the engine running, and the DVM on DC Volts, touch one side to the negative on the battery, and the other to a clean metal part of the engine. the reading should be 0.0, anything else, and you have a ground problem.....
                      Follows to 8.5K just like it did when new.......and hides behind the fuel gauge with a missed speed shift, so yup, I'd say it's 'golden'. BTW, speedo is still spot-on also, and the bike will still only run 85mph.
                        • 5073
                        I think I would rely on some other method of checking ground than the ability of your tachometer to peg itself during a botched shift!
                          Think kevxs was the one questioning a possible issue Sid.When questioned, just commented that the tach on my Venturer has worked perfectly from when I bought the bike new.
                            Hey Greg,
                            IF Yamaha wanted to use an electronic tach, why they didn't just design one to work off of the ignition pulses instead of the ALT is beyond me!? But perhaps they were trying to use a source that was a stronger signal, a lot more volts on one leg/phase of the alt than the trigger side of the coils.
                              • 5073
                              No need to explain, I know exactly what you said! 8-D7
