So when you first turn her over she runs great. no hang, no pops, no stuttering, she just works and works really well.
Once it warms up..about 7 to 8 minutes into riding she starts chugging and cutting out then she starts to back fire and won't go above 2k and then finally sputters out and dies...then it takes an hour to cool down then it fires up again like nothing happened.
I am so confused by this...any suggestions for where to look? I already changed the needle valves so that it would run leaner because it seemed to have to much gas...I also went through and fixed one of my float levels that was causing a little extra gas to run over. Any suggestions at all would be greatly appreciated?
more work to do this Spring!
it didn't do much damage except busting off the ball on the grip for the shifter, and putting a 3 inch across dent in my gas tank
