I'm new to the site, but I've been following along and reading a lot to help with my own cafe racer/brat build.
I decided to attempt the ZRX1200 carb mod in order to run pod filters more easily, and in general just because I was enticed by the idea that I could run modern carbs on my bike
For the vacuum advance, I drilled the hole as described, using a long 1/16" drill bit, and it seems to be in the correct location, except I went too far and drilled all the way through. I had the throttle plates open, so I didn't damage anything, but I was wondering if the larger hole is going to affect anything. Basically it's still slightly uncovered when the throttle plates are closed on the engine side.
With the throttle plate open:
With it closed:
What do you guys think?
I have yet to try it out, but I'm still putting the bike together, so I thought I'd ask first before I start diagnosing a million problems at once. If anything I'll seal the hole and try again; I still have 3 good ones!
With it closed:
