Head Gasket Question
  • RichV
    • May 2013
    • 374
    • Everywhere
    Does anyone use a sealant on their head gaskets? I haven't in the past but I've read it could be good insurance. Is it really needed on the XS1100 engine?
    It would seem to me it would just make a mess if it gets in the cylinder and would cause the gasket to fall apart if you have to remove the head shortly after installation.
    Also, I'm a firm believer in the power of spray cooking oil on gaskets that need to be reused but I don't do it to the head gasket. Does anyone here do that in place of a sealant?
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
  • vanimal5k
    • Apr 2013
    • 160
    • Muskegon, Mich.
    Head Gasket
    The few times I reused a head gasket. I coated both sides with Permatex Ultra Copper Spray. Never had any leaks.
    1979 XS1100SF with a Jardine 4 into 1, ZRX 1200 carbs, 82 XJ rear air shocks, ACCT
    SOLD - 1980 XS1100SG with a Mac 4 into 1, ZRX 1200 carbs, round 160 speedo, 82 XJ rear air shocks, ACCT
      • 8863
      If it is a new gasket, I myself have never used any sealant. Never had any problems.
      • RichV
        • May 2013
        • 374
        • Everywhere
        Yes, it's a new gasket. The copper sealant seems to be good insurance because of it's heat transfer qualities. Just curious to see what everyone else did. I had bad rings so I tore it down again and the head gasket pulled apart. Mainly because I used a sealant. I'm just wondering if it's really necessary.
        Also have:
        • BowlingSS
          • Apr 2015
          • 398
          • Lawrenceville, GA.
          I just used Permatex Ultra Copper Spray on mine. This stuff works great. I also used it on my LS1 head gasket.
          Good luck.
          Bill
          Jardine Spaghetti with Harley Mufflers
            Nope, have never used sealant. No need to. The head gasket isn't subject to any oil pressure.
              • 2120
              I don't use sealant on any of my gaskets (especially head gaskets)- that's what the gasket is for.
              I hate scraping off the mess and damaging the soft aluminum.
              I don't have any trouble with leaks.
              • RichV
                • May 2013
                • 374
                • Everywhere
                I went ahead and installed it without any sealant. None of the gaskets on this engine have any sealant just the case seam. I tried it on the head gasket before and hated the cleanup required when I had to reopen the cylinders to replace the rings.
                Thanks again for all the good advice.
                Also have:
