Can someone please tell me how to install the carbs with the air box? There must be something I am missing. Is there a trick to doing this.
Installing carbs with air box
1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
4 Led Driving Lights
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Braided Lines
R6 4 Piston Calipers
Stainless Bolt Kit
Maier Fairing
Dyna Balancing Beads
Spin On Oil Filter
Stebel Nautilus Horn
Plasti Dip Rims
ISO GripsTags: None
Jared,
Check out this old tutorial thread.
http://www.xs11.com/forum/showthread.php?t=35349
Good luck,
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
On Great Ranger, I too the top airbox bracket and cut it so it only attached to the top of the airbox and used the side bolts to old airbox in place. I'll have to look for a pic.
That's pretty much it in a nutshell.... One thing not stressed enough is when connecting the airbox is when you get two carbs started on one side, install the lower airbox mounting bolt loosely on that side before going to the other side. That will prevent the first two from pulling out as you push the other two in. Makes all the difference.....Fast, Cheap, Reliable... Pick any two
Also Rev- After the Winter turns those boots cold and hard, I like to heat the boots up with a blow dryer (not heat gun), or dunk them in a hot bath of Simple Green to soften the boots up. After that, I spray a little silicone grease on the bell housings prior to install. I wanted to set my bike on fire in April, trying to install my airbox.
On a sidenote, I replaced my carb manifold boots last month. It was time.1979 XS1100F
Originally posted by BowlingSS View PostIt also helps to spray some wd40 on the card boots. It help the carbs go in.
Bill
Here's the video of the install in case it wasn't in the link above.
XS1100 Carburetor InstallMarty (in Mississippi)
Originally posted by TheRev View PostCan someone please tell me how to install the carbs with the air box? There must be something I am missing. Is there a trick to doing this.When a 10 isn't enough, get a 11. 80g Hardbagger
Trick
If you did not check the carbs for leaks prior to the installation, I would strongly advise doing so. Do this using a remote fuel tank or some extended fuel lines off of the bike's tank. Better to find/correct a leak now rather than after they are on the bike. Also a good time to rebuild the petcocks as well.
You should have all three air box screws out so that the box is "floating". While pushing the air box back as far as it will go, angle the carbs in between the intake and air box rubbers. Be careful of the accelerator cable hook up linkage on the carbs so as not to bend it. Hook this linkage up as soon as you can. Proceed to tilt the carbs into the air box rubbers first. Don't force them in. Be patient. Then slide them forward into the carb intakes. Be careful not to bend any of the clamps. Push them out of the way if needed. From here it will take a little finessing to get all 8 of the rubbers aligned to the best position. They shrink over time, so a perfect alignment may not be possible. When you are satisfied of the best position, tighten all 8 clamps. May be necessary to tighten the two outside air box clamps and then pull carbs/air box forward.
The remainder is easy, but take your time. A good sync is in order upon completion. If/when the bike is going to sit for an extended period, place a 2X4under the front wheel. This will keep any leaking fuel out of the crankcase. Check the oil for fuel contamination prior to the sync.1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
EBC Front Rotors
Limie Accent Moves On In 2015
Mike
Originally posted by jwhughes3 View PostOn Great Ranger, I too the top airbox bracket and cut it so it only attached to the top of the airbox and used the side bolts to old airbox in place. I'll have to look for a pic.
John78 E
You could also completely remove that top bracket, and tape the holes with some good duct tape.1979 XS1100F
Going back on with carb bank, first, have clamps loose enough to flip over lip back oughta' way, then spray silicone on inner portion of boots and as you START in with carb bank, hook up throttle cable(makes that chore easier to do). Catch carb bank on bottom of boots then a bit of rocking them to get under upper portion of boots.
The airbox boots can make things a bit more fiddley since they are somewhat loose. At times, they DO need to be rotated a bit for correct alignment!. Clamps back oughta' way, same starting at bottom of boots catching carb bell lip. Takes a bit more rocking and forward pressure, CAREFUL not to rock bike off centerstand. I let calf of my leg hold back against rider peg so this doesn't happen.
Also I DO not reccomend removing that top bracket from airbox! Bend it FORWARD and down of way a bit, or as J.W. Hughes stated, cut that upper loop off, LEAVING the metal mount pieces in place. Removing it WILL open a can of worms internally you don't want to deal with. The airbox has plenty of support from side bolts not putting undue strain on boots without need of upper mount bolt. I 'get it', but that WAS just another bit of overkill that could have been better well spent on the cam-chain adjuster design.
There you have it, the 10min. R/R of the airbox. A JIS(JapaneseIndustrialStandard) phillips driver also reduces time and frustration.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by alaskey2 View PostJust for motivation, I'd like to see this picture. Going to be pulling my carbs for a clean and anything to make carb install a 1 man job would be great!
Try link. I cannot get pics to post on my phone.
