regulators rectifiers
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    so my bike has been down for some time. the regulator rectifier went bad. ihad a used one that seems to work, but takes a while to get to just 14 volts. can one from an xj 1100 be used. i have one from a bike i parted out. i know the charging systems different
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
    • 8930
    It can be made to work, this thread may help you....
    • graybird78
      • Apr 2003
      • 360
      thanks that what i need to know
      graybird78
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Or ...
        If you want a high-quality upgraded replacement, you could opt for one of Geezer's reg/rect units.
        Assuming all other electrical components on the bike are up to par, his unit will give you much better charging just off idle/at lower RPM's.
        You can find them here:
        OregonMotorcycleParts
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
          • 7830
          +1 on Geezers units! had one in a '79 I sold a few years ago, and it was working great! If I have ANY problems with the one in my bikes, I'll be getting another one from him.
          • graybird78
            • Apr 2003
            • 360
            so it looks like the connecter in the main harness has gotten very hot and melted.so more wiring work.i hate wiring.read all the other posts. the xj has 2 black and 2 red wires.does it matter which one gets used.
            graybird78
              Graybird,
              The Red and Black wire pairs on the XJ1100 Rectifier are identical.
              Yamaha used four wires to handle the extra power from the XJ11 alternator instead two thick wires. Since the connector on your XS11 is already burned, now would be a great time to add two more terminals to the harness for the extra wires, or splice the pairs together and go up one terminal size.
