It's alive!!!
  • OMCC
    • May 2014
    • 73
    It's alive!!!
    After almost a year of sitting in my garage I finally got the bike to turn over.
    the petcocks, even after a cleaning, were toast. In any switch position the fuel just flows right out of them. That being said I still connected the vacuum lines just in case. I also added inline fuel filters to each side as well as kill switches (http://www.amazon.com/Oregon-In-Line...BZSKT3W2CE84FT) on each side to keep the carbs from flooding since the fuel flows constantly from them.
    It's idling a little rough right now...I have the idle jets screwed in 8 1/4 turns each which is where they were when I took the carbs apart.
    the other kinda weird thing is that after idling somewhat normally for a minute the engine starts to ramp up to 3-4000 rpms from the 1750-2500rpms it idles at. when starting with the choke out full or half it immediately races to 7-8000rpms
    I have a few more things I HAVE TO take care of before it's road ready
    1. I have to figure out why the flashers don't work
    2. I have to shorten the fuel lines you can see them hanging loose in the video.
    3. I have to change the oil and possibly purchase the spin on adapter from top cat
    4. I have to reconnect the headlight and secure the tacs
    5. I have to replace the missing hanger bolt on the rear caliper.
    6. I have to put back the rest of the plastic and metal
    7. I have to check and fill the tires
    And then theres some thing I want to do
    • Buy and install forward controls
    • repaint gas tank (i really buggered it up)
    • Find a shorter set of pipes (maybe)
    • buy and install kickstart lever
    • buy and install rear footpegs
    • buy and install new seat
    • buy and install saddle bags
    I just wanted to see if you guys can think of anything I forgot and see if you guys had any ideas to make the idle a little smoother and what might be effecting the flashers.
    Thanks again guys couldn't have done it without you!
    79 F Bobber/Cafe Hybrid
    Rasputin on Carburators:
    "It is just a mechanical beast that defies logic."
    Well, ther's a WHOLE lot you've skipped over! Firstly, your taking a big chance of a starting backfire...fire., fuel in oil, and so on.
    Nextly, carbs have to be re-synced. That includes first, a correct mixture setting(where they were don't cut it!), sync all four together.....go BACK thru mixture settings, followed with re-sync AGAIN. Roughly start with a 'bench' setting of a couple turns out from LIGHTLY! seated. Idle will have to be adjusted down as you proceed thru process. Sync AND idle mixture setting are done at LOWEST idle that is smooth(8-900rpm). A correct tune and sync. WILL allow a smooth idle down to 450-500rpm......but under no circumstances run it there, as oil pressure is too low at that rpm. Normal idle setting is 1100rpm.
    BTW, setting for that period of time, and if carbs were NOT drained, a carb removal, dis-assembly and cleaning IS in your near future!
      Way to go, OMCC! I know that feeling well!
      • Gmac
        • Aug 2014
        • 256
        • Huntsville, AL.
        Grats
        I bought a pair of XS's last July, both have been parked since last August as I discovered this forum and began reading about how to bring my bikes up too running and correct working order.
        I'm somewhat picky about getting things in proper working order so after a month or two of reading here I have laid out a path to get both bikes running, in refurbished, safe, running condition.
        I would highly recommend re-greasing every wheel bearing, steering head bearing, swing arm bearing and drive shaft connection. I would highly recommend a premium molybdenum grease as all of these need service to prevent catastrophic failure. The reason is the grease that's there is probably the original factory stuff, 35 year old goo at this point.
        The second thing would be to use DeOxit on every connection and cleaning all the grounds with an abrasive to ensure good connectivity.
        After that you will need to do the carbs, as in cleaning and re-synching.
        After that anything else is fair game.
        PS... Welcome!
        79 SF & 80 LG MNS
        73 & 74 RD 350's
        73 Honda CL 450
        Graveyard - '81 XS850 Special
          • 3193
          Congrats on having it running. That is something that all of us want before we spend more time and money on these bikes.
          You should spend a little time researching carb settings in the manual and on the site though. You will find no one who says 8 1/4 turns out is close to correct on the idle screws. Also if it races to 7-8000 rpms on choke, you need to do these carbs properly.
          It is far to complicated to explain in one short reply but there is a wealth of info on the site. Everyone is a bit afraid of starting in on a carb job but there are no ghosts in the closet. It is just a mechanical beast that defies logic. All of the members here will help out and give their best guesses and links to support you in getting it running correctly.
          Not all of the noises I heard on your vid are necessarily carb related either. Some may be due to exhaust leaks or ignition issues. Again help is available.
          The best advice I can give is to change one thing at a time as wholesale changes do not give you the needed info. Good luck.
            I think OMCC counted 8 1/4 turns from the removed position, not backed out from lightly seated. It's good he thought ahead to record the approximate position to return to, although backing out is the more accurate method.
            OCC: Your symptoms are consistent with a bad vacuum leak. Common places are the intake boots (rubber couplers between the carbs and intake manifold), and the Butterfly Shaft Seals (BSS). You can spray starting fluid or lighter fluid to check for leaks. If you hit a leak, the RPM changes when you spray it.
            Congratulations on getting it going.
            • phatts27
              • Aug 2012
              • 189
              • Clementon, New Jersey
              Double check your vacuum connections. Make sure your ignition vacuum is connected to carb #2 , not the intake boot port.
              Check that your float heights or fuel levels are in spec
              Check for stuck floats and leaking float o-rings
              Check your crankcase oil and change it if there's gas in it
              Sync 'em.
              81 xs1100 SH
              81 xs1100 SH (parts)
              80 suzuki gs550et
              07 suzuki S40
              • OMCC
                • May 2014
                • 73
                Can you expand on this, what am I doing wrong to create this risk?
                I reset the pilots to the 1 and 1/4 out from lightly seated I built a homemade manometer sync should be done today.
                I was smart about this and drained the carbs before I stopped working on it last fall.
                • OMCC
                  • May 2014
                  • 73
                  Thanks Buddy!
                  • OMCC
                    • May 2014
                    • 73
                    Perfect these are going straight to the top of the todo list, Thanks!
                    • OMCC
                      • May 2014
                      • 73
                      I reset the the pilot screw to the 1 and a 1/4 they recommend the bike no longer races up to 7-8000rpms on choke. Radioguylogs was right I was not counting back from lightly seated
                      I need that on a bumper sticker
                      I think you may be right...looking into this now
                      you guys are quicker then AAA
                      Thats a good point I got a lot out of this thread but I'm sure the deeper I go into these fixes the more singular questions I'll be posting.
                      • OMCC
                        • May 2014
                        • 73
                        Yes this is exactly what I did. I ended up resetting the pilot screws to spec the bike sound much better.
                        I think this is part of the issue looking into this now them boots are old and a little ragged
                        • OMCC
                          • May 2014
                          • 73
                          I need some clarification here do you have a picture of this where does the ignition vacuum run from? do it connect to that brass breather tube on carb 2?
                          This is on the todo list
                          done and done!
                          is the crank case oil different from the engine oil? I understand this may be a tremendously dumb question. How do you check it without draining it?
                          Sync 'em.
                          Working on it
                          • OMCC
                            • May 2014
                            • 73
                            Thanks everybody for your continued help!
                              Hey there,
                              The crankcase and Engine oil are the same thing...the engine and the shaft the pistons are on is the crankSHAFT, and therefore the case it's housed in is the CrankCASE...Engine Case, etc. IT can be difficult to check it for the presence of gas contamination without draining it. You can try to smell it thru the filler spout, or you can stick a wooden or clean metal stick into it, get some oil on it and then smell it again to see if you can detect any fuel smell vs., just oil. If you are sure that your carbs haven't leaked into the engine because you took them off, that's one thing, but if you're not sure, then it's recommended to go ahead and drain and replace....ONCE you have fixed the carbs so you won't have to do it again. It takes very little fuel to contaminate the oil enough to cause it to damage crank/piston con rod bearings and such!
                              The Ignition vacuum advance is under the left engine cover....the hose connects to the vac. pot and then comes out behind that cover and up to the carbs where it attaches to the #2 carb body brass port because it's a METERED port, that's why you don't want it on the Intake Boot synch port.
                              The intake boots can look bad bad on the outside, but still be okay on the inside because they are double walled. The mating surface can get messed up from age/heat, rubber gets brittle and crumbles off. After inspecting the inside for cracks, if clear, then you can use some gaskets and sealant to ensure that they don't have any vacuum leaks.
