Thinking about clip-ons for my Special. What mm?
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    A thread here said 37mm as well as MikesXS page. However when I just measured myself I got 41.5mm. I measured just below the triple tree where I assume the clip-on would go. I see 41 and 43mm advertised.
    (my calipers were zero'd out and they are accurate)
    I have a 79 special. Please advise....
    Rob - 79 SF
    • 8672
    That is the headlight ear you are measuring, the fork stanchion is 37MM. I wouldn't clamp over the outside of the ear, there is an air gap between it and the stanchion. You would need to modify /cut the headlight ear to run a 37MM clip on below the upper tree, or slide the stanchions up some and clip on above the TT, gonna lose ground clearance that way.
    • mrhammer2u
      • Aug 2014
      • 472
      • Northern, NJ
      Thanks Phil. So I assume I would slide the headlight ear down a bit? I'm not by my bike or I would look.
      Rob - 79 SF
        • 7785
        Buy some aftermarket headlight ears. A new top triple clamp would be nice, too!
        Put clubmans on it and it's done.
          • 8672
          If you wanted to, an option would be to cut down the top of the headlight ear tubes the same amount as the clip on depth. You would have that unsightly center of the upper TT sticking up where the handlebars used to be. That new upper TT shown above would be a nice option, probably $$ though. I bet you could hack/grind off the center of the stock upper TT to get rid of the old HB mounts.
          • TomB
            • Aug 2006
            • 967
            • Cumbria, UK
            Usually clip ons are used with rearset footrests, I see in another thread you're also thinking about forward footrests. Not sure your combination will be too comfortable.
            Originally posted by mrhammer2u
            I was thinking about forward foot pegs (or controls) but when I hopped on my bike, I'm realizing that I will end up melting my ankles to the bone if I attempted this.
            They sell kits for the XS but how the heck do you run these with our engines being so wide??
            Tom
            • mrhammer2u
              • Aug 2014
              • 472
              • Northern, NJ
              Hi Tom. My bike has been having an identity crisis. It doesn't know if it wants to be a a cafe or chopper...lol. Been researching options. Just bought window style drag bars with a 6" rise to try it out.
              Rob - 79 SF
              • TomB
                • Aug 2006
                • 967
                • Cumbria, UK
                Haha, I know what you mean. I have an XJ11 that I'm thinking of putting ape bars on.
                Not sure how to go about that, does anyone have any ideas? do you use Special top tree?
                Tom
                • 79XS11F
                  • Jul 2006
                  • 3563
                  • Ottawa, Ont. Canada
                  I would recommend drag or low bars. There bikes are somewhat heavy for clip-ons.
                  KEEP THE RUBBER SIDE DOWN
                  1978 XS1100E Modified
                  1978 XS500E
                  1979 XS1100F Restored
                  1981 Suzuki GS1100
                  1983 Suzuki GS750S Katana
                  1983 Honda CB900 Custom
                  • Xarik
                    • Aug 2015
                    • 56
                    • Wisconsin
                    Little bit of a resurrection of this post. You're helping me on another thread about my gas tank, but I'm wondering what you ended up doing with your bars? Mine has straight bars on there and it looks like a trick bike (like a bicycle bike), which is ugly. I'm going for the cafe look, so ones that angle down and inwards would be best....wondering what you did and if you have a picture? I'd rather not put a ton into a new triple tree or grind it down (that'd end up ugly)
                    80 Special Cafe Project
                    • mrhammer2u
                      • Aug 2014
                      • 472
                      • Northern, NJ
                      I went with a supermoto style bar. Glad I did because I did not want to be too over my tank. I'm not claiming to have a cafe bike though.
                      Rob - 79 SF
                      • TomB
                        • Aug 2006
                        • 967
                        • Cumbria, UK
                        Looks good
                        Tom
