Forks
  • mack
    • 2411
    • Ontario, Canada
    Forks
    Were all standard forks bolt caps the same?(Top cap for upper tubes)
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Per boats. 78E-79F were mechanical pre-load, 80G-81H were air.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      ... and don't directly interchange. The threads are the same, but the machining is different enough that the late air caps won't fit the early fork tubes and seal properly without modifying them. The early caps will fit the late tubes, but won't have as much thread engagement, and again won't seal right.
      Another one of those inexplicable changes that Yamaha made...
      • mack
        • 2411
        • Ontario, Canada
        I was
        afraid of that. Ok so anyone have a source for the E/F caps. I'd go on Ebay but I really don't trust it after my previous experience with the crank shells.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
          It's tough to find nice ones. I've got a couple of spares but they're pretty beat up with rounded corners from using a wrong-sized socket on them. Maybe Andreas can come up with a decent pair, have you tried him?
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Will the tubes from the Special fit the Standard lowers ?
            76 XS650 C ROADSTER
            80 XS 1100 SG
              • 8077
              No. I believe the Special forks are longer than the standard forks. I mean tubes.
              • mack
                • 2411
                • Ontario, Canada
                I believe the diameter
                is 1mm smaller in the special as well.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • mack
                  • 2411
                  • Ontario, Canada
                  Tool
                  Didn't I see a thread on making your own tool to freeze the internals on E forks so you can get the bolts out of the bottom for disassembly?
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • Prisoner6
                    • Aug 2013
                    • 1184
                    • Phoenix, AZ
                    (I believe the diameter) is 1mm smaller in the special as well.
                    Actually, the diameter of both Standard and Special fork tubes is identical at 37mm ... but as Marty pointed out, the Special tubes are longer.
                    Marco
                    1979 Honda CBX
                    2002 Kawasaki ZRX1200R
                    WE MISS YOU, DON
                    • Prisoner6
                      • Aug 2013
                      • 1184
                      • Phoenix, AZ
                      Mack,
                      I believe this may be the thread you're referring to:
                      Fork disassembly help
                      Marco
                      1979 Honda CBX
                      WE MISS YOU, DON
                        • 8077
                        I can't remember exactly, but I believe the standard forks are made by KYB and the Specials were made by Showa, or the other way around. Either way, it's two different manufacturers.
                        • Prisoner6
                          • Aug 2013
                          • 1184
                          • Phoenix, AZ
                          Nothing wrong with your memory, Marty ...
                          It's exactly as you described ... Specials have Showa forks, Standards have KYB.
                          Marco
                          1979 Honda CBX
                          WE MISS YOU, DON
