Dead Headlight
  • barrelguy
    • 171
    • Oliver, BC
    Dead Headlight
    Just getting the old girl ready for the season and find that the headlight doesn't work. Fuses are good, installed new bulb, checked/cleaned all connections, all other lights work as they should, just no headlight, ALso checked all the continuity I could think of - seems good. Anybody have any ideas? Many thanks.
    1980 XS 1100 Special
    Mostly stock & original
    Added Yamaha fairing (w/ 8-track!)
    Torpedo bags
    New paint (still) pending
    Stainless brake lines
    Tkat forkbrace
    Coils from Honda 1000
    Previous bikes:
    1968(?) 350 Harley Davidson
    1977 Yamaha 650
    Things to check: diode going to the headlight relay, the relay, left handlebar control connections, high-low switch, headlight ground.
    Try bypassing the headlight relay first (it's under the tank, above/forward of the coils). Unplug the relay, check for power on the red/yellow wire, if present then jumper the red/yellow and blue/black wires together. If the light now works, then either the relay is bad or the diode has failed. The diode will be located in the white wire coming to the relay from the alternator; trace it back until you find it (it will covered with a bit of vinyl) and check that.
    It's usually one or the other of these. If not, you'll need to check for continuity from the relay through the handlebar controls and on to the light.
    • barrelguy
      • 171
      • Oliver, BC
      Thank you Steve. I'll continue the diagnosis.
      Torpedo bags
      Tkat forkbrace
      Previous bikes:
      1977 Yamaha 650
      • Eastcoaster
        • Jan 2012
        • 504
        • oceancity NJ
        Mine was the headlight relay under the gas tank bad connection on the plug
        82 XJ1100J
        81 Venturer
        • barrelguy
          • 171
          • Oliver, BC
          Ok So I have power on the red/yellow, jumpered the red/yellow and blue/black and voila! headlight works. So it will be the relay or the diode. Just for fun I checked continuity on the relay and it is there on the R/Y and B/BL posts but not on the other side. What exactly does a diode look like??
          Torpedo bags
          Tkat forkbrace
          Previous bikes:
          1977 Yamaha 650
          • hamjam
            • 1003
            • Toronto ontario Canada
            try starting the bike
            Seamus Ó hUrmholtaigh
            Niimi Moozhwaagan
            NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
            Any connection between your reality and mine is purely coincidental.
            Member of "FOXS-11" (Former Owner of XS-11)
            and SOXS
            2008 Nomad "Deja Buick'
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              and checking voltage at the white wire at the relay. Set the meter on AC, and you should get 5-6 volts. (The diode makes it a pulsating DC voltage, which confuses the DC meter.) If you have it, the Reserve lighting Unit is the probable culprit. Just went through this routine.
              Andreas has a good price on RLU's.
              CZ
              • barrelguy
                • 171
                • Oliver, BC
                All is good. It is very handy having Andreas living just down the road! Also scored a replacement speedometer for the one that died last year. Thanks for the help.
                Torpedo bags
                Tkat forkbrace
                Previous bikes:
                1977 Yamaha 650
