Gas in the Crankcase/Clutch Problem
    • 3189
    If the bike is on the side stand it will run out of the airbox. If it is on the center stand it will run into the engine. No 2x4 needed or anything else.
    Best to shut the gas off and check the octy for correct operation, so there is no worry.
      • 2066
      Originally posted by sail4free
      ========== Is this an issue with the XS? Or do you turn the key off when you can tell it's starting to run out of gas?
      Jim:
      I don't get blued pipes, even though I removed bluing from the pipes when I bought them. I shut the key off when I hear the engine start to react to the low gas.
